I've been taking some time to decide on what parts I will use and what exactly I will do for the engine rebuild. Right now I'm leaning toward using a higher comp oem piston, for the benefits of cast and oem reliability/quality. I am just a bit hesitant though about having to tune the ecu, but at this point with the 4 Piston head, that may be necessary anyway. Plus, I may not really mind having to tune it.
If I do the higher comp pistons, and then assuming it will be tuned, I figure why not do a mild cam upgrade. Maybe Toda A2 or something similar.
If Ferrea valevtrain makes sense, I'd love to do that. They have different valve and spring options on their website. I have no idea at this point which ones to choose, but would want more of a mild upgrade. They also make rockers, which are much lighter than oem. I wonder if that is worth it? And if using those would compromise reliability? They seem like they would help the engine rev freer, give the cams an easier job (but this is just me imagining in my head).
Here are some Ferrea links:
Valve springs:
https://www.ferrea.com/acura-dual-valve-springs/p699
Valves:
https://www.ferrea.com/acura-5000-serie ... alves/p456
Rocker arms:
https://www.ferrea.com/acura-rocker-arms/p409
So yea, tentative plan is: Oem piston higher comp (maybe aim for c/r of 11 or so). Ferrea valve train with their rockers, and mild cam, 4 Piston head. Imo that would be an epic engine. That might rev to 9k.
More random thoughts: When getting the new pistons, will they be in stock? If I go for a JDM oem piston option, will they be available? Will I need to do block work on cylinders? But then I'd need oversize pistons, and that gets a little complicated. Same thing with deck resurfacing. Also gotta think about bearings. Definitely want to go oem.
Or maybe my block will work fine as is for the standard size new pistons. I do want to clean it up at least, and do anything to improve it, but avoid machine work that would make piston/bearing size adjustments necessary.
This is pretty challenging to decide on parts and what I'll do exactly. But I'm happy to get this experience. Any feedback is appreciated.
