Those undercarriage panels look nice.
Thanks I’m pretty excited about them.
They’re re from ARP sport (Laile) ordered via Nengun (they actually added to their catalog for me). Had to be custom made so took a month and a half or so to get. Also due to size, shipping was as much as the panels :S but everything arrived in great shape and looks quality!
Seeing the hard line guard it would not be hard to make one yourself if you have some fabrication skill and took your time. Could probation do some thing similar for tank and front panel but they are a little more complex.
ZzzzzzzzzzzZz
Just got back from an India trip mid day Saturday. Was over 20hrs of travel to get home from Pune. I’ll be back to work soon though.Stin1 wrote:ZzzzzzzzzzzZz
https://vimeo.com/360171423
Ok, few updates:
New rear ABS sensors went in.
Last bolts for the parking brake cables went in.
Gas tank installed (hopefully for good)
A couple heatshields in place.
And staged the tank shield so I can get it mounted up.
More progress today:
Rr. captive (toe/torque compensator) nut transferred
Rr. trailing + toe + upper control arms transferred
Rr. coilover installed
Rr. Lower control arm installed
Rr. caliper transferred
Rr. (J’s racing braided) brake line installed
Rr. hand brake cable installed
Rr. Abs sensor installed (partial -need a few more bolts)
Rr. Suspension/brake installed
Rr. Wheel staged
Rr. Wheel staged
Left side today
That's got to feel rewarding. Looks great.
Thanks, Better than it going up it’s going up pretty smoothly so far. At least as far as there’s little in the way left to find as surprises and all the rust has been dealt with so not busting bolts etc. Very cathartic.
Plan is next to swing into AC lines and start working toward getting the front subframe in.
The latest:
Subframe (with new rigid collar set)
Steering Rack
UCAs (w/ Ingalls camber/caster kit)
LCAs
98+ JDM ARB
Knuckles
Steering Rack
LCAs
98+ JDM ARB
Knuckles
