Grounding strap
Type R
Re: Grounding strap
Post by Type R » Mon Apr 13, 2020 7:45 pm
Curious what would you pay for a NOS ground strap?
@USDMITR
RJStEEL
Re: Grounding strap
Post by RJStEEL » Mon Apr 13, 2020 8:43 pm
I would pay $150
Re: Grounding strap
Post by hootrscootr » Mon Apr 13, 2020 9:43 pm
coolhandluke wrote:I will keep asking around.
Thanks! I appreciate it.
PeteTheCarFreak
Re: Grounding strap
Post by PeteTheCarFreak » Tue Apr 14, 2020 1:06 am
Stin1 wrote:
hootrscootr wrote: Mon Sep 30, 2019 7:00 pm Mine looks like someone had corn stuck in their teeth, undid the 2 screws, used it as floss, then reattached it. It's that ugly
Lmao. Great post. Reminds me of the itr with a goat on it.
ITR with a goat on it?? Image Hahaha, what's the story behind that?
Re: Grounding strap
Post by Stin1 » Tue Apr 14, 2020 11:00 am
PeteTheCarFreak wrote: Tue Apr 14, 2020 1:06 am
Some guy had a build thread on ht with a yellow itr. On one of the pictures when he first found it. I don’t remember the name . I had some personal checks made using the photo lol
Re: Grounding strap
Post by hootrscootr » Tue May 12, 2020 2:03 pm
I finally found a used ground strap in decent condition for JSH Motors in California. I have it sent to me and it looked a lot better than my current ground strap but it was still not a new 1 like I am still looking for. As I was looking at it, I figured there had to be a way to clean it up so I started looking online on how to clean copper wires. Found a guy online who said to use white vinegar and salt mixed together to clean the copper with. I made up the concoction and submerged the old ground I had in it. Boom! It was working and actually working pretty damn good. I soaked the ground in the solution for about 10 minutes and took a toothbrush to remove the stubborn spots and it actually turned out pretty good. Confident that it worked as advertised, I submerged the newly acquired ground in the solution and used the toothbrush again for the nasty spots. I rinsed the ground in a solution of water and baking soda to neutralize the acid from the vinegar. The results speak for themselves. It looks 10 times better than before, and it will be a great substitute until I find a NOS ground strap.ImageImageImageImageImage
Re: Grounding strap
Post by coolhandluke » Tue May 12, 2020 3:51 pm
Wow, that is a nice DIY tip. Thank you for sharing. :thumbup:
Re: Grounding strap
Post by Stin1 » Tue May 12, 2020 5:25 pm
You are a sinner if you replace things on certain cars vs. do what you just did. We need to remember to restore rather than replacing is better in certain cases. Great job !
yoshi234
Badge Number: 234
Re: Grounding strap
Post by yoshi234 » Wed May 13, 2020 8:41 pm
Nice DIY save hootrscootr :thumbup: !
y :o shi - who wonders if his ground cable's sleeve is short like that?
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
:geek:
Re: Grounding strap
Post by aw614 » Sat May 16, 2020 4:51 pm
The stock ITR one has that little of insulation on it?
My original LS ground looks to have more insulation on it
