- IMG_3947.jpg (321.02 KiB) Viewed 1573 times
I did the same thing with 99-00 Civic lights for my 98 ITR. I am not running the OEM harness. How does the Civic harness compare to the Integra? If they are identical I'd consider taking it off your hands.
ITR Expo 8 & 16 attendee
1998 #729
IG: NOCSUCOW
1998 #729
IG: NOCSUCOW
Which harness are you referring to? The harness on the cabin or from the brown plug in the bay that runs across the radiator support? That one from the bay may possibly be similar. It's been a minute. I can get you some pictures of it to compare. I probably won't sell it unless I have a spare . I can't recall if I have an extra .
Re: 98-0940 Anyone know anything about the caR?
Here's the civic harness. I don't have the integra PDF instructions. There's a ground on the civic harness, not sure if the integra harness has ground. I don't see one but couldn't tell you where the ground would be . I am pretty sure the cabin one won't work. The two white plugs are a jumper between the headlight switch. There's a relay involved on one of the plugs. Brown plug connects to brown wire attached to cabin harness . The other goes to the switch. The jdm cabin version for the civic actually attaches to the cluster. Aftermarket fakes go to the fuse box . One is actually the location for the ash tray / cig accessory. If it's a usdm car, the laws require your fog lights to turn off when your brights are on . I am assuming there's something similar on the integra to the usdm model. The usdm has it on arm rest console and jdm is on the dash. Acklander had some interesting info on a jdm switch mod to work on usdm models.
The harness I'm using I made. It's half PIAA and half ebay for a civic or something.
I had to add a relay off the highbeam to disable the fogs if the highs are activated to pass my state's inspection. I figured that jumper and relay somewhere in there would also do the same thing.
1998 #729
IG: NOCSUCOW
1998 #729
IG: NOCSUCOW
Yes, that is why the jdm versions attach at the cluster. They don't have that law in Japan . I don't recall on the jdm harness if it had a relay , I am pretty sure the fake ones had one. Neither one turned off with the brights.NOCSUCOW wrote: ↑Tue Aug 13, 2019 6:45 am The harness I'm using I made. It's half PIAA and half ebay for a civic or something.
My state doesn't check for that, but I have seen posts about adding a relay on aftermarket and jdm fog lights. Seems rather silly .
After winging it using my brother's manual from a earlier year and the most recent alldata generic evap code I decided I needed the correct 98 manual . I am hoping I have resolved this p1457 but It's the first thing I decided to read. I noticed this on our purge valve.
Round plug on 98 b18c5 purge but not other models?
I’m still using the single combined pdf scan
Wish I had something more navigable
I managed to get the 2001 supplement in paper (for what it’s worth there’s not much in it)
Where did you find a printed copy of the 98 manual? I thought they were out of print on Helms last I checked? Not sure if I’d want paper though. I’d just end up with oily fingerprints all over in it. LOL
IIRC 94-96? also had evap solenoid normally open
97+ changed to normally closed
I think mine is a 98 manual, but I haven't looked at it since I had coolant get soaked on it and it still feels sticky/moist over a year later
I bought it on eBay . I can post anything you want me to . I can't pm them on this site . If you want to send me your number I can text them too.
