Grounding strap
Re: Grounding strap
Post by hootrscootr » Sat May 16, 2020 11:48 pm
That's the USDM stock ground strap on the right side of the lower pic vs the used 1 I have bolted in place. It supposedly came off of a JDM type r. Looks identical and insulation is the same color and length.
CW_ITR
Re: Grounding strap
Post by CW_ITR » Sun May 17, 2020 8:27 am
I'm also on the hunt for an OEM strap (took mine off over 10 years ago and can't locate it smh), but for the time being I picked up a 2020 Acura RDX ground strap until I can locate the correct one.
Re: Grounding strap
Post by hootrscootr » Sun May 17, 2020 5:27 pm
CW_ITR wrote:I'm also on the hunt for an OEM strap (took mine off over 10 years ago and can't locate it smh), but for the time being I picked up a 2020 Acura RDX ground strap until I can locate the correct one.
Dang, that's super clean!
Re: Grounding strap
Post by Stin1 » Sun May 17, 2020 6:03 pm
If anyone is interested I found the goat pic but I can’t get it from this old phone Image
CW_ITR
Re: Grounding strap
Post by CW_ITR » Sun May 17, 2020 7:15 pm
hootrscootr wrote: Sun May 17, 2020 5:27 pm
Thank you!!
Re: Grounding strap
Post by RTW DC2R » Wed Aug 19, 2020 6:59 pm
Not sure if this is legit or even available but figured I'd post in case someone wants to check it
Re: Grounding strap
Post by hootrscootr » Wed Aug 19, 2020 7:00 pm
Thanks!
Re: Grounding strap
Post by hootrscootr » Wed Aug 19, 2020 7:19 pm
Pmd the guy, not for sale. The search continues.... but at least I have a better looking 1 on the car now vs the old 1.
Type R
Re: Grounding strap
Post by Type R » Wed Aug 19, 2020 7:21 pm
Definitely legit. There are some floating around.
@USDMITR
Re: Grounding strap
Post by hootrscootr » Wed Aug 19, 2020 7:24 pm
Floating around? Yes Obtainable? Not for me but eventually 1 will surface or someone with a few will sell me 1.
