What are the differences between these radiators: 19010-P73-A02 and 19010-P73-A03
Post by Outrun » Tue May 26, 2020 11:12 pm
Bernardi, acurapartswarehouse, irunoem, etc don't have 19010-P73-A03 in stock due to being discontinued. The stock radiator in my 97R is leaking at the top plastic tank despite having about 44k miles on it. I've seen 19010-P73-A02 as an alternate part number and was wondering what the difference is between -A02 and -A03. Thanks!
Purplepassiongsr
Re: What are the differences between these radiators: 19010-P73-A02 and 19010-P73-A03
Post by Purplepassiongsr » Wed May 27, 2020 7:26 am
Showa vs. denso units? Just my guess.
Post by aw614 » Wed May 27, 2020 7:44 am
Fan mounting shroud mounting locations? Did the shrouds match in part number? I recall with non Type R integras, some models had a different shroud mounting point that I didn't realize on my old automatic.
Post by coolhandluke » Wed May 27, 2020 1:57 pm
aw614 wrote: Wed May 27, 2020 7:44 am Fan mounting shroud mounting locations? Did the shrouds match in part number? I recall with non Type R integras, some models had a different shroud mounting point that I didn't realize on my old automatic.
Automatic DC2/4's had a transmission cooler in the radiator, which would impact fan mounting.
Post by Stin1 » Wed May 27, 2020 2:23 pm
They are all discontinued. A02 and a03 . I also asked Amayana about availability on the jdm unit . They were also discontinued. Super annoying. I am sure the all aluminum radiator keeps water temps down . In my garage it sure seems like it keeps under hood temps up and burning myself on the radiator simply checking on things to me was my reason for removing it. The last time I checked I had a hard time finding an OEM style radiator.
Post by Outrun » Wed May 27, 2020 3:49 pm
Sucks they're not available. I was hoping to keep it all stock with all Honda parts. Not sure if it's feasible to repair. I haven't really checked the radiator. I just smelled coolant when driving around to charge the battery as I only drive it once or twice a month. Currently considering all aluminum radiator or Koyo's S2028 OE replacement radiator.
Post by Stin1 » Wed May 27, 2020 4:06 pm
Outrun wrote: Wed May 27, 2020 3:49 pm Sucks they're not available. I was hoping to keep it all stock with all Honda parts. Not sure if it's feasible to repair. I haven't really checked the radiator. I just smelled coolant when driving around to charge the battery as I only drive it once or twice a month. Currently considering all aluminum radiator or Koyo's S2028 OE replacement radiator.
They used to repair these . Not sure if they do or how OEM it would look. You are in Az ? My car has no visible leaks but I noticed the smell of coolant on my latest drives . Any links on the koyo replacement? Nippon also lists one . It doesn’t seem to be type R specific.
Post by coolhandluke » Wed May 27, 2020 5:11 pm
The OEM radiators are a sandwich of plastic/alunimum/plastic. As the plastic ages, pressure or fluid seeps from the plastic ends, causing the smell or leaks.
There might be OE-style replacements on RockAuto.com/etc., but quality is TBD. An all-aluminum unit (Fluidine/Koyo/etc) is what I would buy for longterm quality. However, if OEM appearance is a concern, even at a potential reduced quality, check out this list from RockAuto by Denso/others:
https://www.rockauto.com/en/catalog/acu ... iator,2172
Post by Outrun » Wed May 27, 2020 5:25 pm
http://koyoradracing.com/products/searc ... h+Products
https://www.evasivemotorsports.com/mm5/ ... KOYO-S2028
The Koyo is about $120. I also found a Duralast A1741 OE replacement for $99 at Autozone. The Koyo is a copper radiator. Not sure about the Duralast.
https://www.autozone.com/cooling-heatin ... 237395_0_0
Post by Stin1 » Wed May 27, 2020 6:56 pm
Outrun wrote: Wed May 27, 2020 5:25 pm http://koyoradracing.com/products/searc ... h+Products
I did the koyo oem replacement on a em1. It doesn’t burn the shit out of me . The top tank and bottom are all metal.
