where to buy a new steering rack? help
TYPE-RP
Post by TYPE-RP » Fri May 29, 2020 12:27 pm
im just curious to see if anyone has bought a steering rack for their type r recently and where did they go. i called acura already and they are discontinued
Re: where to buy a new steering rack? help
Post by aw614 » Fri May 29, 2020 12:34 pm
Did you read the previous thread that had all the information about the OEM reman rack? The info is there and part number. Is it discontinued now?
TYPE-RP
Post by TYPE-RP » Fri May 29, 2020 2:06 pm
i spoke with them over the phone but they told me they were long gone. but when i search that number on their site says its in stock. maybe ill try and put a order in for it and see what happens?
Post by coolhandluke » Fri May 29, 2020 5:11 pm
TYPE-RP wrote: Fri May 29, 2020 2:06 pm i spoke with them over the phone but they told me they were long gone. but when i search that number on their site says its in stock. maybe ill try and put a order in for it and see what happens?
Who did you call? I would recommend IRUNOEM, as they sponsor Type R Expo and their Parts Manager owns a '97 ITR. As mentioned, the new racks are gone, but Acura (used) to offer a re-manufactured unit.
Reference:
https://www.acuraexpressparts.com/irunoem
TYPE-RP
Post by TYPE-RP » Fri May 29, 2020 6:19 pm
shows the rack on there is discontinued as well :(
Post by aw614 » Fri May 29, 2020 6:25 pm
The closest thing to a new oem rack is the OEM reman rack or you buy all the assorted seals and rebuild your current rack yourself
TYPE-RP
Post by TYPE-RP » Fri May 29, 2020 6:30 pm
is the part number you gave me the number to the whole assembly?
Post by aw614 » Fri May 29, 2020 6:51 pm
I believe so, you get the inner tie rods with the reman. And I believe there is fluid inside the rack
TYPE-RP
Post by TYPE-RP » Fri May 29, 2020 7:24 pm
okay im just gonna place the order and see what happens. thanks for all your help man i appreciate it.
Post by coolhandluke » Mon Jun 01, 2020 10:27 am
TYPE-RP wrote: Fri May 29, 2020 7:24 pm okay im just gonna place the order and see what happens. thanks for all your help man i appreciate it.
I would recommend calling IRUNOEM. Cris will give you a straight answer before spending $XXX without clarity.
