Page 1 of 1
Solved (closed thread) : ashtray support (dash section)
Posted: Wed Nov 11, 2020 5:46 pm
On the off chance someone has a spare black Teg dash they can carve up for me....
The clips that hold up the front of the ashtray assembly are broken on my dash so the ashtray assembly hangs down.
If I can get this piece from any doner teg w/ a black dash I can plastic weld this section into my dash. Unfortunately my old LS had a tan dash so I’d like to try to source from a car with a black dash. Ideally I’d like the entire section cut down from the sides of the stereo cut out.
Let me know if anyone has a junk dash they can cut up and what you think it’s worth
Thanks,
Alan
Re: WTB: ashtray support (dash section)
Posted: Wed Nov 11, 2020 8:08 pm
by DC231
aklackner wrote: ↑Wed Nov 11, 2020 5:46 pm
Thanks,
Alan
i have a donor dash id be willing to cut up for you if the desired section is good.. itll take me a few days to get time to go check it out..
Posted: Wed Nov 11, 2020 8:23 pm
Awesome thanks
Posted: Wed Nov 11, 2020 8:59 pm
by Justadad
I have an entire black dash that is in good shape other than the passenger airbag plug end was cut off. I’m located in pa and would be glad to meet up with you if your are remotely local.
Posted: Wed Nov 11, 2020 9:10 pm
@justadad Thanks for the offer. I’m out in LA though so I’m unable to take you up on that.
Posted: Wed Nov 11, 2020 9:33 pm
by Justadad
Was worth a shot. Good luck to you!
Posted: Wed Nov 18, 2020 6:54 pm
Ended up taking a shortcut and determined that this section of the dash isn’t visible so used the action from the tan LS dash.
Welded in place with a sharpie paint job
