CT Engineering Icebox Intake with K&N Filter?
spratte
Badge Number: 97-#00057
Post by spratte » Wed Jun 23, 2021 5:02 pm
I'm getting mixed signals on if I can use a OE style replacement K&N with the CT Engineering Icebox Intake.
A put a K&N on a few months ago, but now looking at the Icebox since the factory resonator down below is in a minimum of two (not factory produced) pieces.
Sporky82
Badge Number: searching
Re: CT Engineering Icebox Intake with K&N Filter?
Post by Sporky82 » Wed Jun 23, 2021 5:13 pm
You can use the K&N oe filter in the icebox but you will not be able to use the CT air horn/filter adapter. It's designed to use a generic K&N cone filter or the unifilter foam filter heel/toe sells. One of the benefits of the CT air filter adapter is the built in velocity stack which does help these motors breath.
spratte
Post by spratte » Wed Jun 23, 2021 5:22 pm
Sporky82 wrote: Wed Jun 23, 2021 5:13 pm You can use the K&N oe filter in the icebox but you will not be able to use the CT air horn/filter adapter. It's designed to use a generic K&N cone filter or the unifilter foam filter heel/toe sells. One of the benefits of the CT air filter adapter is the built in velocity stack which does help these motors breath.
:thumbup:
Post by Dave7CDMTYPER » Wed Jun 23, 2021 9:46 pm
You can also use the Spoon air filters, if you like top shelf. :trophy:
