Sonoma Raceway 11/11-11/12
Day 1
Foggy start, track time delayed an hour.
Re: Sonoma Raceway 11/11-11/12
Day 1:
Alan / ATC5 and his 98:
- Badge Number: 234
More please!
y shi - who's looking fwd to driving 234 again!
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
00 Bolt EV
Day 1 was challenging due to accidentally signing up for a lower run group. This group wasn’t particularly aware, didn’t point, and was dangerous (braking) at times.
Onto pics...
Eduardo making deals
New RCrew BBK:
Onto pics...
New RCrew BBK:
Nice wheels.
- Purplepassiongsr
Nice brakes. How do those compare to a twin block setup?
- white rocket
Looking good Ry. How are you liking the Alcon caliper set-up? Same as Spoon twinblock? Can OEM-size pads be used? Can you notice the unsprung weight savings with those 2 piece rotors?
<------looking for excuses to upgrade my NSX klapperz when there really isn't any need
Here is a clip someone made from last weekend:
https://youtu.be/FQ5F3X0jFuQ
This new setup is a big improvement so far. Normally, I would struggle to go two track days without needing to bleed. Note, I️ have been struggling with brake issues the past few years. Improving my brake technique would help this issue, especially at tracks that are hard on brakes, like Laguna Seca.Purplepassiongsr wrote:Nice brakes. How do those compare to a twin block setup?
This BBK held up very well during two days at Sonoma/I️nfineon Raceway. The wet weather added challenges, due to surface and tire changes, but I️ was able to start gaining experience. My biggest take away is brake application. This BBK forces you to be smooth and light on brakes. Mashing the brakes or over applying will lead to lock up, especially in the wet. I’m still working towards confidence, this weekend at Laguna Seca will be a good test.
No, these are a different pad size. Previously, when I️ ran 2pc Stoptech rotors, I️ could tell a different. However, this time I️ changed too much (some out of my control) to be able to pinpoint individual changes like rotor. You are reminding me to weigh the rotor for comparison and to finally start a 98-1040 thread here though.white rocket wrote:Looking good Ry. How are you liking the Alcon caliper set-up? Same as Spoon twinblock? Can OEM-size pads be used? Can you notice the unsprung weight savings with those 2 piece rotors?
PS- Just buy my Spoons.
