USDM vs JDM Exhaust Manifold - fit the same or different?
SKO_ITR
Post by SKO_ITR » Mon Mar 07, 2022 4:03 pm
I believe it's a 4-1 on the JDM and a 4-2-1 on the USDM? Does thee JDM fit on the US car's?
Thanks!
Klasse
Re: USDM vs JDM Exhaust Manifold - fit the same or different?
Post by Klasse » Mon Mar 07, 2022 9:14 pm
'96 spec jdm has a cast 4-2-1. Everyone forgets that. Unsure of that's the same as the usdm, but i think there is a difference in cat length. Might be made up on the exhaust side.
9701TypeR
Post by 9701TypeR » Wed Mar 09, 2022 10:15 am
Neither 96 or 98+ will connect to a usdm cat, too short.
SKO_ITR
Post by SKO_ITR » Fri Mar 11, 2022 9:36 pm
Does JDM heat shield fit on USDM header?
9701TypeR
Post by 9701TypeR » Sat Mar 12, 2022 11:39 am
SKO_ITR wrote: Fri Mar 11, 2022 9:36 pm Does JDM heat shield fit on USDM header?
No it will not
Purplepassiongsr
Post by Purplepassiongsr » Mon Mar 14, 2022 9:34 am
What is everyone using for a high flow cat these days? Looking to get one made up in jdm length. The jdm cat I picked up doesn't have an 02 sensor.
Post by aw614 » Mon Mar 14, 2022 8:57 pm
I bought a GESI cat and also a 2.5in adjustable test pipe for the piping so I could get it eventually welded together with flanges.
James0933
Post by James0933 » Mon Mar 14, 2022 10:03 pm
J's racing sells a test pipe in the JDM length with brackets to fit the appropriate oem cat shields for $200. The shields can be purchased from Amayama for about $25 for each piece.
Purplepassiongsr
Post by Purplepassiongsr » Tue Mar 15, 2022 11:26 am
Thanks for the feedback gents :drink:
