Page 1 of 1
Machine gun funk antenna
Posted: Tue May 10, 2022 4:54 pm
This is all about the integra oem unit.
Re: Machine gun funk antenna
Posted: Tue May 10, 2022 4:57 pm
Did you have to remove your crackpipe from your antenna?
Posted: Tue May 10, 2022 5:04 pm
- FA12FD1F-82A4-4D55-B658-A001A837376D.jpeg (393.78 KiB) Viewed 2158 times
Posted: Tue May 10, 2022 5:05 pm
- 94E1C598-5F4C-4854-8E5D-424B6530D60E.jpeg (339.3 KiB) Viewed 2157 times
Posted: Tue May 10, 2022 5:13 pm
39152-sr4-003
Posted: Tue May 10, 2022 5:24 pm
Posted: Tue May 10, 2022 5:29 pm
If you had a jdm antenna you have the wrong mast.
Posted: Sat Jun 04, 2022 4:54 pm
I have some updates to this. I finally received the jdm mast from amayama. Over night parts from Japan are apparently made in China now. The part number applies to jdm nsx and jdm itr. The part number is thicker at the base and longer than the us mast. It also included the crack pipe which was permanently attached to the piece.The crack pipe will not fit in the mast ,
- 59BEE693-265F-497A-B448-98A5C12F1DD4.jpeg (2.17 MiB) Viewed 1817 times
Posted: Sat Jun 04, 2022 5:01 pm
Notice the base is thicker and also that the us version may work without the black sleeve.
- DF3FC1BE-3BAE-4F5F-A33C-5809B9CF979E.jpeg (3.25 MiB) Viewed 1816 times
With the jdm part number I had to remove the crack pipe but it was bonded. I had to totally destroy the metal and plastic. I reused the original plastic bushing from the original.
Posted: Sat Jun 04, 2022 5:22 pm
On to the nut
- AAC81A82-00D8-41C5-BAA2-150CC97A3273.jpeg (2.74 MiB) Viewed 1811 times
The jdm part number appears to have a slightly different thread pitch and uses a different part number. Curious to see what an original car has.
The o ring is completely different on the two as well.
The antenna now operates flawlessly. No machine gun funk . Silence on opening and closing.
