FS- IL: 1997 Acura Integra Type R # 153- Edit: Keeping!
Posted: Fri Jul 08, 2022 12:09 pm
Hello all,
For sale is USDM 1997 Acura Integra Type R #153 of 320 in Championship White.
This is a two owner vehicle that was a previous theft recovery. The vehicle was stolen from Salah khuro. At the time the car was stock and had roughly 77k miles. The trans, engine, interior, suspension, and rims were taken at the time.
The car has been pieced back together over the last ten years and it's currently fully functional, titled and registered.
Installed is a 1998 spec JDM B18C Type R engine and transmission. A full size rim is included as a spare.
Everything on the car works including the optional A/C.
No serious rust or corrosion including underneath the vehicle.
All VIN numbers are present aside from the one on the driver's door jamb
The vehicle has been serviced at Arlington, IL Acura with receipts in hand which include:
Timing belt package, knock sensor, valve adjustment, full tuneup, axle, clutch,flywheel, axle seal, tires, alignment, and brake fluid replaced. 98 spec jdm itr motor and trans. Full size rim as spare.
***Edit: Keeping***
***Edit: Keeping***
