Replacing Hazard / Defroster Switches
Parth
Badge Number: DC2-1103421
Post by Parth » Sat Aug 20, 2022 2:45 am
The hazard and defroster switches are sun damaged and could use replacing. Is there a better way to remove them than to just manhandle them with a flathead screwdriver like I've seen in videos? I'm afraid that doing that will cause the buttons below the switches to shift out of place and no longer line up properly.
Thanks
oddomatik
Badge Number: 98-0542
Re: Replacing Hazard / Defroster Switches
Post by oddomatik » Sat Aug 20, 2022 1:25 pm
This is not to say there isn't a better way, but that's basically what the manual says. Maybe just put a microfiber between the screwdriver and any point of contact with other interior trim?
Screen Shot 2022-08-20 at 11.23.30 AM.png (155.64 KiB) Viewed 1914 times
Parth
Post by Parth » Sat Aug 20, 2022 9:30 pm
oddomatik wrote: Sat Aug 20, 2022 1:25 pm This is not to say there isn't a better way, but that's basically what the manual says. Maybe just put a microfiber between the screwdriver and any point of contact with other interior trim?
Appreciate the help, will definitely use a microfiber cloth
