Best non-ITR lower control arms for certain coilovers??
SKO_ITR
Post by SKO_ITR » Mon Sep 05, 2022 11:02 pm
Hello!
I'm installing the Ground Control Special Purpose coilovers (different than their yellow Koni/Eibach kit). It requires the rear lower control arms to be swapped for the non-ITR fork style which are the 92-95 Civic and non Type R Integra arms. The problem is these cast arms are not as wide, and provide 1" gap for the sway bar mounting (at least the ones I got)
Does anyone know if there is a better set of arms that is for the fork and also fit the stock IT sway bar, and has the mounts for the brake sensor bracket/cable? Was trying to stay away from the aftermarket billet style but I'm open those.
https://groundcontrolstore.com/products ... a257&_ss=r
Re: Best non-ITR lower control arms for certain coilovers??
Post by coolhandluke » Tue Sep 06, 2022 3:14 pm
I would opt for non-R DC2/4 integra Rear LCA's as a starting point. Kingpin Machine could also be an option to leverage your current arms, via replacing bushing with sphericals. Kingpin could machine the sphericals to match the desired width.
