- since day one, I have not seen Speedo needle move. Tach works, lights in cluster all functioning, temp needle and gas needle all functioning.
- swapped to a different VSS unit. (Little different shape to housing, but same gear and length and plug) No dice
- checked VSS unit against multiple images and pictures and put correct unit into trans. (we had taken the ones i have in and out a few times at this point to test and not sure which was in first) Right one is in now....
- swapped engine harness (We had some broken plastic and tabs, coolant fan wasnt coming on, and hoped maybe VSS wiring issue) no luck. fan is working now as it should, still no VSS. Harness looks good though! LOL
- went through the manual and checked two fuses it referenced, both were good.
- VSS troubleshoot begins a voltage check with a "test relay harness"... basically an in-line harness with test leads coming out of it.... Yeah, dont have that.... So we used a meter to test. Harness has continuity at signal wire from engine harness end at VSS plug to Orange wire at ECU plug. Ground wire on harness end is grounded.... Now here is where sh!t goes weird....
The power/voltage at the harness end is reading 145.xx volts.... HUH? Something is not right... We disconnect the Orange wire coming out of ECU and test the voltage coming out of the ECU at that pin and its 145.xx.... Power on, this ECU is outputting 145.xx volts.... WTF IS GOING ON.... ECU fried?? Let's plug in another.
- swap out for another OEM ECU, test pin again, same thing. 145.xx volts...... WHAT IS GOING ON! LOL
I'm all types of ears for suggestions. We had gone through what I had thought was all of the ground locations and cleaned them up, maybe we check that again??
Also a kicker to boot, my radio does not work...
HELP!!
