Rust Repair
4DoorITR
Rust Repair
Post by 4DoorITR » Thu Dec 15, 2022 12:59 pm
Winter is here! Time to rip off the bandaid and fix my quarter panel rust. This is a DB8 Type R. Looking for some advice as to how I can tackle this the CORRECT and PERMANENT way.
'96 DB8 Type R
'92 EH9 EX
Re: Rust Repair
Post by coolhandluke » Thu Dec 15, 2022 1:22 pm
I would go on the hunt via junkyards/forums for a donor 4DR shell to source replacement sections. This will require an experienced body shop to cut and replace (weld + smooth) these sections. The rear doors add a layer of complexity, but I don't feel this is a deal breaker for a quality shop.
oddomatik
Badge Number: 98-0542
Re: Rust Repair
Post by oddomatik » Thu Dec 15, 2022 1:27 pm
4DoorITR wrote: Thu Dec 15, 2022 12:59 pm Winter is here! Time to rip off the bandaid and fix my quarter panel rust. This is a DB8 Type R. Looking for some advice as to how I can tackle this the CORRECT and PERMANENT way.
Cut out cancerous part completely, form an identical piece to go in its place (or cut one from a donor panel), weld 'er in, grind down welds and body fill minor pockmarks to restore original body line, blend in some matched paint or just get the whole thing repainted.
Most of those things are outside my skillset, but from what I know that's the "right" way to do it.
D'oh, @coolhandluke beat me to it.
I'd personally (given my lack of experience) grab a battery powered angle grinder and hack a junkyard car up to grab as large a surrounding piece as I could, then take that into a body shop and have them do the rest. I'll get set up for welding and paint here one of these days... I have all the stuff, just a lack of space and experience.
Re: Rust Repair
Post by coolhandluke » Thu Dec 15, 2022 1:40 pm
oddomatik wrote: Thu Dec 15, 2022 1:27 pm ....I'd personally (given my lack of experience) grab a battery powered angle grinder and hack a junkyard car up to grab as large a surrounding piece as I could, then take that into a body shop and have them do the rest. I'll get set up for welding and paint here one of these days... I have all the stuff, just a lack of space and experience.
I like the battery-powered idea here. A dremel + a diamond cutting wheel could be a lower entry option.
4DoorITR
Re: Rust Repair
Post by 4DoorITR » Thu Dec 15, 2022 1:48 pm
:) Well, I did just recently acquire a Milwaukee M12 die grinder and a cutoff wheel.
'96 DB8 Type R
'92 EH9 EX
oddomatik
Re: Rust Repair
Post by oddomatik » Thu Dec 15, 2022 2:16 pm
4DoorITR wrote: Thu Dec 15, 2022 1:48 pm :) Well, I did just recently acquire a Milwaukee M12 die grinder and a cutoff wheel.
Bingo!
Check out AHC Garage and Paint Society on YouTube for inspiration on the paint part. Since the colors on these Champ White ITRs vary widely (with at least 3-4 different shades used), I'd have a professional who has been doing it a while match and blend it in. Or repaint if the whole car needs it (mine does).
Re: Rust Repair
Post by coolhandluke » Fri Dec 16, 2022 8:50 am
Queue Tim Taylor Tool Time :mrgreen:
