Looking for Acura Type R fuel Rail and pressure regulator. Does not have to be both if you have the regulator alone I will buy it.
Thanks
Wtb oem type R fuel regulator and fuel rail
Re: Wtb oem type R fuel regulator and fuel rail
I suggest ordering WVE 5G1001 from Rockauto https://www.rockauto.com/en/moreinfo.ph ... 69&jsn=369
It was the same thing in the box that was OEM on my car. WVE 5G1001 on the left, OEM from my car on the right. I pressure tested it and either they were the same, or my luck was both of them were broken in the same way.
What is it for? There’s cbr that uses same pressure regulator pressure.shuttlepilot wrote: ↑Mon Sep 25, 2023 10:45 pm I suggest ordering WVE 5G1001 from Rockauto https://www.rockauto.com/en/moreinfo.ph ... 69&jsn=369
- oddomatik
- Badge Number: 98-0542
The interchange # listed on RockAuto is a type R part #.
Did you just end up returning the part back to Rock Auto?shuttlepilot wrote: ↑Mon Sep 25, 2023 10:45 pm I suggest ordering WVE 5G1001 from Rockauto https://www.rockauto.com/en/moreinfo.ph ... 69&jsn=369
Vouches: RTW DC2R | 9701TypeR | James0933 | joteeter
