98-0413
Bitanga
98-0413
Post by Bitanga » Tue Dec 12, 2017 12:43 am
Here is my daily driven 98 Integra Hype R.
I had a thread on ITRCA but I do not feel like spamming a bunch of posts and starting from the beginning lol.
Mod List (12/11/2017)
Motor | Engine Bay
Spoon Sports Cam Gears
Spoon Sports Air Cleaner
Spoon Sports 4-2-1 Header
Spoon Sports Exhaust B-Pipe
Spoon Sports N1 Axle Back
Spoon Sports Sub Silencer
Spoon Sports Baffle Oil Pan
Spoon Sports Heat Barrier Tape
Spoon Sports Style Valve Cover
Spoon Sports Carbon Plug Cover
Spoon Sports High Tension Cord
Spoon Sports Oil Filler Cap
Spoon Sports Radiator Hoses
Spoon Sports Radiator Cap
Spoon Sports Radiator Stays
Spoon Sports Thermostat
Spoon Sports Thermo Switch
Spoon Sports Clutch Hose Line
Spoon Sports Change Rod
Spoon Sports Titanium Bolts
Spoon Sports Magnetic Drain Bolts
Spoon Sports Reservoir Tank Covers
Spoon Sports Certification Badge
Interior
Spoon Sports Gauge Cluster
Spoon Sports Steering Wheel
Spoon Sports Titanium Shift Knob
Spoon Sports Rear View Mirror
Works Bell Short Boss Hub
Works Bell Quick Release
K-Tuned Pro Circuit Short Shifter
CDM Airbag Delete Tray
Recaro Pole Position Bucket Seat
Recaro Side Protector
USDM ITR Checkered Floor Mats
USDM ITR Optional Trunk Mat
USDM ITR Carbon Fiber Dash Pieces
JDM ITR Pedal Set
JDM ITR Carbon Fiber Radio Delete
JDM ITR Carbon Fiber Window Switches
JDM ITR Carbon Fiber Personal Box
JDM ITR Clock Delete
JDM ITR Non SRS Column Cover
JDM ITR E-Brake Handle
JDM ITR Door Handle Bezels
Exterior
Spoon Sports Carbon Fiber Mirrors
Spoon Sports Tow Hook (Front)
Spoon Sports Tow Hook (Rear)
Spoon Sports Wiper Blade Set
Spoon Sports Team Sticker (800mm)
Wheels | Suspension
Spoon Sports SW388 (15x6.5 +42)
Spoon Sports Twin-Block Calipers
Spoon Sports Brake Pads (Rear)
Spoon Sports Strut Tower Bar (Front)
Spoon Sports Strut Tower Bar (Rear)
Spoon Sports Lower Tie Bar (Front)
Spoon Sports Lower Tie Bar (Rear)
GC/Koni Coilovers & Extended Top Hats
Ingalls Adjustable Front Camber Kit
Goodridge SS Braided Brake Lines
Bitanga
Re: 98-0413
Post by Bitanga » Tue Dec 12, 2017 1:29 am
Long story short... I went to Stickydiljoe's Year 9 Meet in SoCal in October and I spun a bearing on the way home. When I originally bought the caR the previous owner spun a bearing due to low oil. I had the crank checked, turned and took a chance. It only lasted 2 years (12k miles) but I beat on the motor everyday. I spun it at 8k in 5th gear (use your imagination lol) on the way back from SoCal. *shrug*
I ended up picking up a low mileage 98 spec R motor from my friend who got rear ended. He bought the long block from Rcrew a few months prior and only ran it for 2-3 months. Never even reached his first oil change.
Got the new swap in just in time for the plusONEcrew X ATS Garage 12th Annual Toy Drive.
I freshened the new swap up with the following:
JDM ITR 96 Spec Transmission (freshly rebuilt by Rcrew, new OEM 1-2, 3-4, 5-R synchros and an ATS 3rd)
ARP Cylinder Head Studs
Spoon Sports Head Gasket
Spoon Sports Gen 1 Cam Gears
Spoon Sports Baffled Oil Pan
OEM Valve Cover Gasket Set
OEM VTEC Solenoid Gasket
OEM Throttle Body Gasket
OEM Radiator Coolant
OEM Transmission Fluid
OEM Timing Belt Cover (A)
OEM Timing Belt Cover (B)
OEM Timing Belt Cover (C)
OEM Oil Pump
OEM Oil Pump O-Ring
OEM Oil Strainer Gasket
OEM Rear Main Seal
OEM Exhaust Manifold Gasket
OEM Distributor O-Ring
OEM Camshaft Plug
OEM IACV Hose (IN)
OEM IACV Hose (OUT)
OEM Outlet Bypass Hose
OEM Oil Cooler Hose (IN)
OEM Oil Cooler Hose (OUT)
OEM Heater Core Hose (A)
OEM Heater Core Hose (B)
OEM Heater Core Hose (C)
I blew my ITR motor on Monday and that same week I threw a rod on my GSR. :lol:
I don't feel like talking about that though... :? :moneyburn:
noahf
Re: 98-0413
Post by noahf » Tue Dec 12, 2017 12:24 pm
Ill make the rebuilds feel less painful by buying your spoon cluster ;)
Re: 98-0413
Post by coolhandluke » Tue Dec 12, 2017 1:13 pm
I'm glad to hear you were able to get the car up and running. :thumbup:
Let's get together soon.
Vtecwreck
Re: 98-0413
Post by Vtecwreck » Tue Dec 12, 2017 2:04 pm
Glad you were able to get it on the road quickly, love the simplicity.
Re: 98-0413
Post by Dc2-ProductionS » Tue Dec 12, 2017 2:33 pm
Looks like you went with swapping the oil pump to USDM and USDM vtec solenoid... :thumbup: :thumbup: :thumbup:
I'm guessing it all worked well since I didnt hear from ya again!!
Good job, love your caR. I loved your IG vid of your Dad driving it and pulling into the lot. Looks so good. Hahaha I found the link, posted below. Hope you dont mind!
https://www.instagram.com/p/BXWbGGgHLrq ... by=bitanga
Re: 98-0413
Post by Dave7CDMTYPER » Tue Dec 12, 2017 5:10 pm
That's too bad about both cars' engines.
Nice list of spoon parts. Only thing you're missing are spoon driveshafts. ;)
noahf
Re: 98-0413
Post by noahf » Tue Dec 12, 2017 5:53 pm
Dave7CDMTYPER wrote: Tue Dec 12, 2017 5:10 pm Nice list of spoon parts. Only thing you're missing are spoon driveshafts. ;)
also the super rare spoon earthing kit
white rocket
Re: 98-0413
Post by white rocket » Fri Dec 15, 2017 10:47 am
Looks good Mikey :thumbup: . Always been a fan of this car. Glad you're up and running again :trophy:
Bitanga
Re: 98-0413
Post by Bitanga » Mon Dec 18, 2017 12:49 am
noahf wrote: Tue Dec 12, 2017 12:24 pm Ill make the rebuilds feel less painful by buying your spoon cluster ;)
Lol thanks for the offer!
coolhandluke wrote: Tue Dec 12, 2017 1:13 pm I'm glad to hear you were able to get the car up and running. :thumbup:
Let's!
Vtecwreck wrote: Tue Dec 12, 2017 2:04 pm Glad you were able to get it on the road quickly, love the simplicity.
I'm glad as well, thank you!
Dc2-ProductionS wrote: Tue Dec 12, 2017 2:33 pm Looks like you went with swapping the oil pump to USDM and USDM vtec solenoid... :thumbup: :thumbup: :thumbup:
Yeah, thanks for the help!!!
Dave7CDMTYPER wrote: Tue Dec 12, 2017 5:10 pm That's too bad about both cars' engines.
Lol.
noahf wrote: Tue Dec 12, 2017 5:53 pm
Yes! Lol.
white rocket wrote: Fri Dec 15, 2017 10:47 am Looks good Mikey :thumbup: . Always been a fan of this car. Glad you're up and running again :trophy:
Gracias!
