00 PY #0271 Forsale NJ 700hp! SOLD
SOLD SOLD SOLD SOLD
Up for possible sale is my 00 py R. First off I understand that this car will not be everyone's cup of tea. I also understand that I will not get back near what was put into this car. That being said the car was meticulously put together with only high quality brand new parts. No short cuts were taken here. I would rate the car as a 8/10 both the interior and exterior are extremely clean and rust free. Car spend most of its life in the south until purchased by me in august of 2016. I am the 6th owner (3 of which were a husband and wife flipping the title back and forth). The title is clean with matching vins on all panels except jdm front( done by previous owner during respray).
Car has matching motor and tranny. VIN # JH4DC2316YS001564 160k on chassis. Less than 2500 on rebuilt engine. Car is rarely driven and only in perfect weather.
I am willing to answer any questions anyone may have about the car. Car is located in CENTRAL NJ
The car now sits as a fully built turbo car Tuned by Jeff Evans in PA that made 695hp 475tq on 25psi e85 fuel. Car made 530hp 340tq 15 psi 93 oct.
Mod list: All parts are under 5k and that may even be a high estimate
Suspension/Brakes/Wheels
Spoon wheels 15x5x114 +43
Toyo R888R 225/50/15
Spoon brake pads front and rear
Hawk quiet slot rotors front and rear
BFG ss lines
New Oem calipers front and rear
PIC select R2 coilovers 10k front 8k rear
Cusco 25mm rear sway bar
Cusco front and rear upper strut bar
Engine
Sheepey built T4 top mount turbo kit dual turbo smart 40mm wgs
Back door 800hp intercooler
Borg Warner EFR 8374 1.05 AR twin scroll
LHT custom 3 inch exhaust vbanded to magnaflow muffler custom LHT tip
Skunk 2 pro 70 mm throttle body
Skunk 2 pro intake manifold
Hondata thermal manifold gasket
Skunk 2 pro stage 2 camshafts and gears
Supertech 80lb turbo springs and retainers
Ferrea standard size 6000 series valves intake and exhaust
Ferrea bronze guides, seals, locks
ARP head studs
Golden eagle head gasket
All new oem seals top and bottom
Oem timing belt and tensioner
Oem water pump
Oem oil pump
ACL race series bearings
AEBS sleeved block to 84mm by Z10 engineering
Wiseco 84mm pistons 9:5:1 comp
Manley turbo tuff rods
Moroso oil pan
Mishimotor half rad with hoses
Spal Ultra hd fan
Innovative steel mounts 95a rubber
Go Autoworks drain to block catch can
Comp clutch stage 4 sprung 6puck kit
Comp clutch street light flywheel
Fuel
ID 1700cc injectors with PNP clips
Walbro 450lph e85 pump
DW hard wire kit for fuel pump
AEM fuel Rail
AEM fuel pressure reg
AEM fuel Filter
B&m fuel gauge
Electronics
Hondata s300 v3 with boost by gear
Innovate ECB-1 gauge shows boost, e%, fuel temp, AFR
Spoon specific parts
Wheels
Power adjusting mirrors
spark plug cover
spark plug wires
steering wheel
brake pads
On to the pics.... more can be taken on request
[/URL
[URL=http://s384.photobucket.com/user/rsxblueguy/media/69b24351-9ec1-4d04-be66-873657d023c2.jpg.html]
(hood is popped)
BFG ss lines
Engine
ARP head studs
Oem water pump
Oem oil pump
Moroso oil pan
Spal Ultra hd fan
Fuel
AEM fuel Rail
AEM fuel Filter
B&m fuel gauge
Electronics
Wheels
spark plug cover
spark plug wires
steering wheel
brake pads
[/URL
(hood is popped)
Re: 00 PY #0271 Forsale NJ Feeler...
Very nice and local to me. Whish I had the funds. Glws
I bet this is a blast to drive. GLWS
Would love to see a short video clip of this thing, running, on boost
As the original owner of #271, Im super interested. I sold the car right after college 13 years ago and regret it...Will be in touch to come see it!
00-271, 98 Comptech S/C NSX, 98 M3
- white rocket
That's one hell of a build and a lot of car for $23k. If it wasn't for importation regulations I'd be all over this. GLWS
Thanks bro!white rocket wrote: ↑Wed Jan 17, 2018 11:16 am That's one hell of a build and a lot of car for $23k. If it wasn't for importation regulations I'd be all over this. GLWS
I should be picking it up tomorrow, thanks for pulling for me
