1998 keyless entry pdf or part list ?
Hello, my car had the original keyless entry system installed. Later in life a after market system was installed and was eventually removed by the previous owner , as it was draining the battery . I know some of the wiring is present , as it is clearly labeled keyless and appears dealer installed rather than factory. I am tempted to order the fob but I am not a fan of wasting money. The fob also appears identical other than the Acura logo to my 97 civic fob. I don't know if alarm shops remove the factory equipment or disable them. It's been a while since I looked into it but I was having problems confirming the FCC for the Acura.
Re: 1998 keyless entry pdf or part list ?
The three button one is for a 96-98 civic and appears identical to the Acura one . I would still love the PDF instructions.
Most of those program, I have a few acura and honda remotes if needed
You are the Acura part guy on the other site right? Do you have the PDF for install or the programming instructions?
