oil pan baffle necessary at expo?
I picked up an oil pan baffle and I'm not sure if I can get it installed before the expo. I was just wondering is it a must to have? how many don't run one? I'm in the amateur grouping, running a stockish integra type r with re71 r tires and koni/gc suspension. I've done a couple track days with just the stock oil pan, but just wondering if this track and my setup will require one?
Re: oil pan baffle necessary at expo?
I would recommend one. But most of us have tracked a lot without one. I don’t have one on the rhd. I just keep the oil topped off.
- jayhaire
It's nice to have, but you can get by without one if:
- keep oil level up (watch this before each session)
- not running R-comps
That was our general rule ~15 years ago. Novice group is slow enough to keep the lateral Gs down also.
I've never run 1 and never had a problem at VIR or Road America but like the others said, watch the oil level and run the good stuff.
Youll be fine just check your oil after each session. Ive done a lot of tracking and have only lost VTEC once through a corner. It was at VIR at Expo 16 through Hog Pen but that corner has high compression grip and lateral G's. My oil was very low too
Dominion doesnt have any high grip corners like Hog Pen so I think anyone will be fine there with a stock pan and sufficient oil level.
thank you guys. i'll do without it for the expo.
install at track? lol
a few extra hands and a welder??? Lol. actually, you made me think about something. what's the craziest repair/mod done at an expo? This is my first so, maybe a vet can chime in...
Head swap expo 9? Or Craig replacing valves expo 14?
- jayhaire
Willard doing a final drive install at Expo 3?
I think we've had just about everything done at Expo over the years. 18 years...the event is legally an adult now.
