Page 1 of 1
Which Works Bell Hub Model Number are you using?
Posted: Thu Jul 12, 2018 4:22 pm
by Jdmspoonitr
Any of you running a short Works Bell hub on your 2001 ITR and have the model number handy?
I am trying to purchase a WorksBell Short Hub that works with the existing SRS/Horn Reel.
Originally I purchased model 223S since the website I purchased from listed it as compatible with DC2. Turns out it doesn't fit and is made for S2000/Fit/RSX steering shaft which is larger in diameter.
The company sent me questions regarding steering shaft diameter and also the reel configuration. I'll have to go poke around in the car tonight, but if someone know what model they purchased that would certainly be easier!
The attachment Schematic2.png is no longer available
Thanks,
Ken
Re: Which Works Bell Hub Model Number are you using?
Posted: Fri Jul 13, 2018 8:38 am
Was there anything for EG Civics? That should work with integras
Posted: Fri Jul 13, 2018 9:06 am
Ek has a different spline that is same as rsx and s2k . The eg and Dc both have the same spline.
