Replacing wheel studs?
Aquafina
Post by Aquafina » Sun Sep 02, 2018 6:29 pm
Will pulled his ARP install writeup on H-T and the old forum is gone.
I'm looking at OEM studs, not extended. Do OEM studs require the hub to be pulled for install? Wheel bearing is fine and I'd rather not replace it if I don't need to.
Whoopee Doo Racing High Performance Transmission builds and parts.
MFactory Official North American Installer, Torco, Action Clutch, Gear-X, OS Giken, Synchrotech, Rocket Motorsports, Hasport, MTM Custom Ratio Gear North American Distributor
Re: Replacing wheel studs?
Post by DC231 » Sun Sep 02, 2018 7:09 pm
yeah you have to pull the hub
Xian
Post by Xian » Mon Sep 03, 2018 8:04 am
I know it’s not ideal but I popped a hub “part way” out to swap studs one time. Used the press to pop each stud out of the hub and then pressed the hub just far enough out to swap the studs (I went with ARP, extended). Pressed the hub back into the bearing and then pressed the new studs all the way into the hub.
Post by coolhandluke » Wed Sep 05, 2018 10:44 am
Front or rear studs? Fronts, yes, the rears, no.
I can re-host my pictures from the 97 install a few years ago.
Aquafina
Post by Aquafina » Thu Sep 06, 2018 4:14 pm
Fronts.
Post by aw614 » Thu Sep 06, 2018 8:23 pm
The method Christian mentioned is what I heard from a dealer tech friend does when replacing broken studs on cars.
He had to do it on my Integra when I needed a stud replaced on my car. It worked and I haven't had any wheel bearing issues.
audipwr1
Post by audipwr1 » Fri Sep 30, 2022 1:30 pm
Bringing to front.
I need to put on extended studs on my front hubs.
I am confused by what OEM parts I need to swap out to do this - do folks just buy a replacement front bearing (pull hub, remove old bearing, press studs, new bearing and old hub back in)?
The kits online show the hub and bearing being sold as one part?
So question is - is there a way to just buy right bearing (if so PN) otherwise do I have to buy this combo hub / bearing part?
Thanks.
oddomatik
Badge Number: 98-0542
Post by oddomatik » Sun Oct 02, 2022 2:36 pm
audipwr1 wrote: Fri Sep 30, 2022 1:30 pm So question is - is there a way to just buy right bearing (if so PN) otherwise do I have to buy this combo hub / bearing part?
Thanks.
44300-S04-A01 or 44300-S04-A02
FWIW if you're lazy like me, you can hammer out old studs without removing the hub, and grind off part of the head so the new one slides right in. I've done it on a few different cars including the ITR without any notable issues.
Post by coolhandluke » Tue Oct 04, 2022 2:06 pm
audipwr1 wrote: Fri Sep 30, 2022 1:30 pm Q1: I am confused by what OEM parts I need to swap out to do this - do folks just buy a replacement front bearing (pull hub, remove old bearing, press studs, new bearing and old hub back in)?
Yes, anytime the hub is removed, the bearing through be replaced.
audipwr1 wrote: Fri Sep 30, 2022 1:30 pm Q2: The kits online show the hub and bearing being sold as one part?
The bearing and hub are separate pieces. Some dealers/etc. might create kits, as if one drives on a
audipwr1 wrote: Fri Sep 30, 2022 1:30 pm Q3: is there a way to just buy right bearing (if so PN) otherwise do I have to buy this combo hub / bearing part?
Yes, one can just purchase the bearing. PN: 44300-S5A-008
Related, there are two types of ARP among other stud options, I documented them in this extended lugs thread:
viewtopic.php?p=16770&hilit=arp#p16770
oddomatik
Post by oddomatik » Tue Oct 04, 2022 11:51 pm
coolhandluke wrote: Tue Oct 04, 2022 2:06 pm Yes, one can just purchase the bearing. PN: 44300-S5A-008
Interesting... That's not showing up on Integra charts on amayama. Same size as the one I listed previously?
