Just when I thought 234 was ready to go w/ just minor prep, axles threw a hissy fit...which leads to a bunch of "might as well"
Both axles out so might as well replace the axle seals. Need to remove the header to access the seals on the driver's side. Might as well change out the cracked 5zigen header back to JDM header. While the header is out might as well change out the leaky cat donut gasket also. Front suspension was semi taken apart, might was well get an alignment and tyre balance.
y shi - who hopes there's no more chitls to do!
@carluminum
Expo West Prep
- Badge Number: 234
Expo West Prep
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
00 Bolt EV
Re: Expo West Prep
Looking good!
Radiator was pulled to get header out?
- Badge Number: 234
Re: Expo West Prep
Thanks.
The OG Koyo is super fat so it had to come out first.
00 ITR #234
00 Bolt EV
00 Bolt EV
Re: Expo West Prep
Good stuff y0shi! I am in your boat, I wrapped my Expo prep last weekend as well:
-Alignment
-Pad swap
-Pad bed-in
I aim to run through checking the front/rear bolts and general visual, otherwise, I am all set!
-Alignment
-Pad swap
-Pad bed-in
