PLX Fluid Pressure Module/sensor (bnib)
Posted: Mon Oct 29, 2018 10:16 am
Hi,
I’m selling a brand new PLX fluid pressure module (supports 2 sensors).
Great way to add oil & fuel pressure monitoring either standalone or input direct to ecu/datalogger. This module is hard to come by at this point since PLX hasn’t had stock for several months and it’s unclear if they will make more. This is one of the nicer modules that had the red anodized aluminum case.
Update: PLX just confirmed these modules are discontinued, they don't anticipate making any more of these. This is very likely one of the last new kits that will be available. PLX will be replacing their old sensor module line with a new combined sensor module they expect to launch in 2019.
Includes:
(1) sensor module w/ wiring required to connect power and chain with other PLX sensors.
(1) vdo sensor included along with required wiring to connect to module. Has second post to directly trigger warning light or buzzer (ground switched).
If you have an s300/data-logger/digital dash or any other plx sensors like their wideband you can chain this sensor into a single digital input.
If you don’t already have an s300 you can still use stand-alone with either a gauge (analog 5v or rs232) or the PLX Bluetooth adapter to connect directly to your smartphone.
I ended up with this kit since an international seller sent me the incorrect kit and the seller was nothing but problems so I cut my losses and am just selling this kit.
I listed for $200 + shipping with an auction starting at $150. If anyone here wants this kit before any bids come in I’ll end the auction since I’d rather see someone here take it.
LMK if there are any questions.
https://rover.ebay.com/rover/0/0/0?mpre ... 3523199290
Includes:
