ya you gotta spend a few bucks but $XX is cheaper than $90.
been mentioning this in other threads so decided to make one and hopefully will help everyone out
honda P# 72623-SHJ-A21
odessey actuator for the door, same shape mold and internals
pop open and swap motor and other parts, reassemble enjoy
Rear Hatch/Trunk Actuator Repair Fix Solution
- IMAG0888_zps8c0a90e4.jpg (59.02 KiB) Viewed 2200 times
- IMAG0887_zpsyq7e3xsz.jpg (81.07 KiB) Viewed 2200 times
- IMAG0886_zpst1n6lqlw.jpg (72.7 KiB) Viewed 2200 times
Re: Rear Hatch/Trunk Actuator Repair Fix Solution
There was also a user here that 3D printed the piece that worked.
In my case, the actual electrical part failed and not the plastic gear.
Excellent work, thank you for sharing.
ShuttlePilot posted this link over on H-T a few years ago with Eric the Car Guy's video and he mentions if you don't hear the a noise while using the latch, its the switch that is bad. It seems to be located closer toe the antenna area?
https://honda-tech.com/forums/acura-int ... e-3303104/
Same thing happened to this owner of a SSBP GSR on youtube https://www.youtube.com/watch?v=DelxRAkfpLY
Has anyone had the actual switch go bad and changed it?
Unlike the actuator, part number 74810-ST7-A01 is discontinued.
