Page 1 of 1
Rear Hatch/Trunk Actuator Repair Fix Solution
Posted: Wed Jan 23, 2019 9:04 pm
by Chase_acura
ya you gotta spend a few bucks but $XX is cheaper than $90.
been mentioning this in other threads so decided to make one and hopefully will help everyone out
honda P# 72623-SHJ-A21
odessey actuator for the door, same shape mold and internals
pop open and swap motor and other parts, reassemble enjoy
Re: Rear Hatch/Trunk Actuator Repair Fix Solution
Posted: Thu Jan 24, 2019 9:57 am
There was also a user here that 3D printed the piece that worked.
In my case, the actual electrical part failed and not the plastic gear.
Posted: Fri Mar 01, 2019 3:22 pm
Excellent work, thank you for sharing.
Posted: Tue Aug 02, 2022 9:16 pm
ShuttlePilot posted this link over on H-T a few years ago with Eric the Car Guy's video and he mentions if you don't hear the a noise while using the latch, its the switch that is bad. It seems to be located closer toe the antenna area?
https://honda-tech.com/forums/acura-int ... e-3303104/
Same thing happened to this owner of a SSBP GSR on youtube
https://www.youtube.com/watch?v=DelxRAkfpLY
Has anyone had the actual switch go bad and changed it?
Unlike the actuator, part number 74810-ST7-A01 is discontinued.
