stock suspension ?s
ITR822
stock suspension ?s
Post by ITR822 » Tue Aug 22, 2017 3:45 pm
hey guys. My ITR is currently on lowering springs. I am looking to put it back to stock height. My question is, are GSR integra struts/ springs/ shocks the same? This may be a dumb question, but i just had to ask. thanks yall!
also, i found a PY i might be picking up shortly. Need a black still.
Re: stock suspension ?s
Post by Dave7CDMTYPER » Tue Aug 22, 2017 3:50 pm
No GSR suspension is higher and not as stiff. Way different. Plus it has more understeer.
Gotin
Badge Number: 01-1112
Post by Gotin » Wed Aug 23, 2017 7:49 am
You can get the stock setup from hmotorsonline for a great price. Clean product and shipped well.
-BJ-
Dave-ROR
Post by Dave-ROR » Wed Aug 23, 2017 10:23 am
Dave7CDMTYPER wrote: Tue Aug 22, 2017 3:50 pm No GSR suspension is higher and not as stiff. Way different. Plus it has more understeer.
Also, the rear shocks from a GS-R won't even bolt up unless you swap rear LCAs as well.
OP, plenty easy to find OEM ITR shocks and springs, just keep at eye out online for them.
-Dave
Drives.. too many f'ing cars.
white rocket
Post by white rocket » Wed Aug 23, 2017 12:22 pm
It might be even easier to source the JDM stock suspension as HMO and other similar importers should have available stock on hand. I have noticed folks asking the moon for stock USDM suspension due to the current ITR hype.
Post by coolhandluke » Wed Aug 23, 2017 12:55 pm
white rocket wrote: Wed Aug 23, 2017 12:22 pm It might be even easier to source the JDM stock suspension as HMO and other similar importers should have available stock on hand. I have noticed folks asking the moon for stock USDM suspension due to the current ITR hype.
Good point. I have sourced used complete JDM suspension setups in the past for cheaper than going rates. If sourcing from a reputable shop (Ex: HMO), the JDM units are likely lower mileage and should be in good working condition.
Post by Dave7CDMTYPER » Wed Aug 23, 2017 1:52 pm
Yes just be careful with used suspension. I got my set of jdm from JSH I believe. Now it's blown after like 500 miles. So you never know what kind of condition they'll be in. I should have got mine from HMO.
Dave-ROR
Post by Dave-ROR » Wed Aug 23, 2017 1:56 pm
Eh, I'd only want the new springs. Run some Bilsteins or similar. OEM used ITR dampers at this point are a crapshoot at best.
-Dave
Post by jayhaire » Wed Aug 23, 2017 4:52 pm
Dave-ROR wrote: Wed Aug 23, 2017 1:56 pm Eh, I'd only want the new springs. Run some Bilsteins or similar. OEM used ITR dampers at this point are a crapshoot at best.
Yep, those Bilsteins you had before were great. :thumbup:
Post by coolhandluke » Wed Aug 23, 2017 7:32 pm
cheezthis wrote: Wed Aug 23, 2017 4:52 pm
They live on, the 97 was on them when I sold it.
