WTB breather pipe
WTB breather pipe
Post by DC231 » Fri Apr 12, 2019 8:43 am
looking for breather pipe from intake pipe to valve cover 17135-P73-010
Vtecwreck
Re: WTB breather pipe
Post by Vtecwreck » Wed Apr 17, 2019 7:05 am
Just bought a GSR one from HMO, from what I read it seems that it’ll be a bit longer than the ITR one. I’ll update once it arrives! GLWF
Post by DC231 » Wed Apr 17, 2019 11:02 am
Vtecwreck wrote: Wed Apr 17, 2019 7:05 am Just bought a GSR one from HMO, from what I read it seems that it’ll be a bit longer than the ITR one. I’ll update once it arrives! GLWF
i look forward to hearing your input.. thanks 8-)
Post by aw614 » Wed Apr 17, 2019 3:33 pm
Apparently the B16 breather pipe worked for my friend on his EG hatch with the ITR intake arm and b16a, another option to consider.
itielf
Badge Number: 98-340
Post by itielf » Fri Oct 30, 2020 9:55 pm
Did you ever got the GSR part did it worked? Anyone know the B16 part number?
Post by DC231 » Sat Oct 31, 2020 7:41 am
itielf wrote: Fri Oct 30, 2020 9:55 pm Did you ever got the GSR part did it worked? Anyone know the B16 part number?
No I haven't yet... I will update once I decide what I'll be using.
touringteg
Post by touringteg » Sat Oct 31, 2020 8:21 pm
I faced this myself and bought a used JDM ITR breather tube from a UK eBay seller R-motion. I test fit my friends JDM 96 ITR tube first. The JDM DC2R breather tube and hoses is nearly identical. It appeared to be slightly shorter to the intake tube but it’s not noticeable. Note that the seller mistakenly sent me the UKDM breather tube which has an extra bracket on it. I mailed it back and he sent the correct one.
I refinished my tube in low gloss black and it looks fresh and OEM.
https://www.r-motion.co.uk/
ImageUntitled by touringteg, on Flickr
itielf
Post by itielf » Mon Nov 02, 2020 11:35 am
Do you happened to know which one is from this pic?
Screen Shot 2020-11-02 at 12.34.15 PM.png (468.38 KiB) Viewed 1585 times
touringteg
Post by touringteg » Mon Nov 02, 2020 12:32 pm
Yes I do since I have spent way too many hours researching the DC2 ITR breather tube :lol: (I have 3 or 4 spares from various Hondas that do not fit)
The upper right in the photo is the UKDM ITR breather tube with the extra square bracket. Note that the UKDM coolant hoses are orientated in different directions that JDM/USDM.
The lower left one (the straight rubber hose piece has been cut short) is the JDM ITR breather tube. Fits both JDM and USDM/CDM cars. The coolant hoses are the correct orientation. If I remember correctly the USDM/CDM has a longer end with an angle cut to go into the air intake tube but JDM still works fine. :thumbup:
itielf
Post by itielf » Mon Nov 02, 2020 6:40 pm
Thanks wow you are the expert!
I ordered lets see how it goes when it arrives
