The motor has 120k miles and could use a rebuild. The tranny has a fifth gear high rev slight grind; otherwise, perfect.
The swap includes long block, tranny, ECU, wiring harness, shift linkages, axles, radiator, hoses, etc.
It's not for sale. I just want to know what such a swap would go for.
Hmotors has similar swap between 3,800-4,600. Thoughts on following that pricing model for this?
What's fair price for a 2000 USDM B18C5 full swap?
Re: What's fair price for a 2000 USDM B18C5 full swap?
Those hmotor swaps would usually be lower mileage imo, like around 60k miles or so. That price, around $4k, is the value for a swap that doesn't need a rebuild. For your case maybe a little lower toward $3k?
sounds good. 3,000 sounds fair to me. thanks for the input!
You can’t really compare a usdm Type R motor to a JDM. They made over 10x the amount of jdm Type Rs Usdm motors are much more desirable and valuable. You can also get a good idea of the mileage on a Usdm motor if it still has the vin. Jdm motors you will have no idea of mileage. Most companies have been advertising 30-60k miles on jdm motors for over a decade now. I can gaurantee that this is not accurate info anymore Why would they cut up a 20k car to sell it for a fraction of the money in parts? Most of the swaps have well over 100k now. They swap on a new valve cover to freshen up the appearance and put it up for sale.
@USDMITR
I'm with Type R on this.. no possible way a JDM swap is worth as much as USDM swap.. C5 block is much more valuable than C blocks.. even needing rebuild if the C5 still has VIN intact and is complete valve cover to oil pan intake to header then I would say just the engine is worth 3k. I paid more than it would've cost me for a brand new transmission from Acura to buy the VIN matching transmission for my 01 PY when I located it. I would've paid the full price I paid just for the casing half.
Also for reference I paid 2600 for the 98+ JDM full swap that's in my 01 right now. It has the HMO stamps on the block and trans, I found the swap in Lake City Florida. That was complete engine with OEM header and Shields, trans, mounts, axles, harness, ecu, radiator, linkage. I have an RDOT engine and the VIN matching trans that will be going in after I finish buying gear set parts for the trans
Japan has very different laws and registration costs for old cars. A car that was removed from service a decade ago isn't going to have any additional mileage.Type R wrote: ↑Tue May 28, 2019 9:28 pm You can’t really compare a usdm Type R motor to a JDM. They made over 10x the amount of jdm Type Rs Usdm motors are much more desirable and valuable. You can also get a good idea of the mileage on a Usdm motor if it still has the vin. Jdm motors you will have no idea of mileage. Most companies have been advertising 30-60k miles on jdm motors for over a decade now. I can gaurantee that this is not accurate info anymore Why would they cut up a 20k car to sell it for a fraction of the money in parts? Most of the swaps have well over 100k now. They swap on a new valve cover to freshen up the appearance and put it up for sale.
Whoopee Doo Racing High Performance Transmission builds and parts.
MFactory Official North American Installer, Torco, Action Clutch, Gear-X, OS Giken, Synchrotech, Rocket Motorsports, Hasport, MTM Custom Ratio Gear North American Distributor
Im pretty sure if you called steve at hmo and offered him a usdm c5 swap for a jdm swap he would do it 100%.
Usdm swaps with vins are extremely valuable. In socal in the last year they have sold for over 5k.
