DC2 Rear Sway Bar Guide
Posted: Wed May 29, 2019 12:28 pm
For those wishing to refresh OEM bushings or upgrade, this can serve as a starting point.
OEM
1.) USDM 22mm
Rate: 292lbs/in | 5.2kg/mm
Weight: 8.4 lbs | 3.78 kg
Rear Sway Bar PN: 52300-ST7-Z01 (discontinued)
Rear Sway Bar bushings PN: 52315-ST7-Z01
2.) JDM 23mm
347lbs/in | 6.2kg/mm
Rear Sway Bar PN: 52300-ST7-Z11 (discontinued)
Rear Sway Bar Bushings: 52315-ST7-Z11
OEM Parts that work with both 22mm & 23mm:
-Bushing Holder: 52308-SS0-000 (2x)
-Bushing Holder Bolts: 93403-08020-08 (4x)
-End link (Complete): 52303-ST7-Z00 (2x)
-End link bushing: 52314-ST7-Z00 (2x) *Not required if purchasing complete
-End link bolt to RSB: 90175-ST7-Z00 (2x)
-End link bolt to RLCA: 90120-SB0-003 (2x)
-End link bolt to RCLA washer: 94103-10400 (2x)
Aftermarket - Static:
1.) Cusco 25mm
Rate: 406lbs/in
PN: 321311B25
Weight: 8.82lbs
1.) Eibach static 22mm
Rate: 423lbs/in | 7.6kb/mm
PN: 343954 / BWSC-0500
Weight: TBD
2.) Mugen static 26mm
Rate: TBD
Weight: TBD
Aftermarket - Adjustable:
1.) Eibach 25mm 3-way adjustable
-Position 1: 418lbs/in | 7.5kg/mm
-Position 2: 533lbs/in | 9.5kg/mm
-Position 3: 630lbs/in | 11.3kg/mm
PN: 354164 / 4086.320R
2.) ASR Redbar 25.4mm / 1''
Weight: Red bar weight: 7.0 lbs| 3.15 kg
Position 1: 418 lbs/in | 73 N/mm
Position 2: 533 lbs/in | 94 N/mm
Position 3: 630 lbs/in | 111 N/mm
3.) ASR 32mm Hollow 0.95''
Position 1: 503lbs/in | 9.0kg/mm
Position 2: 635lbs/in | 11.4kg/mm
Position 3: 740lbs/in | 13.2kg/mm
Position 4: 850lbs/in | 15.2kg/mm
4.) ASR 32mm Hollow 1.2''
Position 1: 643lbs/in | 11.5kg/mm
Position 2: 761lbs/in | 13.6kg/mm
Position 3: 828lbs/in | 14.8kg/mm
Position 4: 980lbs/in | 17.5kg/mm
5.) Progress 22mm
PN: 62.1041
Position 1: 310 lb/in
Position 2: 360 lb/in
Position 3: 410 lb/in
Known Issues
1.) ASR spherical endlinks in conjunction with HyTech Twinloop exhaust
-Scenario 1: Eibach 3-way adjustable rear sway bar, only clears on stiffest 3/3 setting
-Scenario 2: JDM 23mm rubs
Change log:
4/29/20 - Rev4
-Added Cusco 25mm RSB details
-Added JDM 23mm PN
-Added Known Issues section addressing ASR endlinks + HyTech TL issues
5/29/19 - Revision 3
-Added Progress PN
5/29/19 - Revision 2
-Added Mugen 26mm and Progress adjustable
WIP:
-Mugen 26mm weight and rates
-Eibach 22mm static weight
OEM
1.) USDM 22mm
2.) JDM 23mm
1.) Cusco 25mm
Rate: 406lbs/in
PN: 321311B25
Weight: 8.82lbs
Weight: TBD
Rate: TBD
Weight: TBD
5.) Progress 22mm
PN: 62.1041
Known Issues
Change log:
4/29/20 - Rev4
-Added JDM 23mm PN
-Added Progress PN
WIP:
