Tech - Type R Transmission Gearing, Shiftpoints, and Final Drive Discussion
Posted: Thu Aug 01, 2019 10:37 pm
Let's start by highlighting OEM configurations. If you haven't already visited www.integratyper.org, check it out! Matt has already documented much of the DC2 and DC5 information, such as this Comparison sheet.
This thread will document transmission discussions across Type R models.
DC2
JDM 1995-1996
Transmission Code: S80 with 4jhd gearbox
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
4th: 1.107 (115 mph)
5th: 0.848 (143 mph)
FD: 4.400 *Add 80mph cruising RPM
R: 3.000
LSD: Helical
***Add chart + shift RPMs
USDM & CDM 1997-2001
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
JDM 1998-2000
Transmission Code: S80 with ne3 gearbox
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
4th: 1.034 **Add max speed
5th: 0.787 **Add max speed
FD: 4.785 *Add 80mph cruising RPM
R: 3.000
LSD: Helical
UKDM & EDM 1998-2000
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
AUDM Oct 1999- Jul 2001
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
FD:
R:
LSD:
Aftermarket DC2 Final Drive
Option 1: 4.785
Option 2: 4.9
Aftermarket DC2 Gearing
MFactory Close Ratio Gearset Version A ****Add PN
in-progress
1st: 3.070
2nd: ***Confirm OEM ratio
3rd: 1.636
4th: 1.310
5th: 1.054
FD:
MFactory Close Ratio Gearset Version B ****Add PN
in-progress
1st: 3.070
3rd: 1.667
4th: 1.357
5th: 1.129
FD:
MFactory Close Ratio Gearset Version C ****Add PN
in-progress
1st: 3.070
3rd: 1.700
4th: 1.410
5th: 1.207
FD:
DC5
JDM & AUDEM Jul 2001- Jul 2006
Transmission Code: Y2M3
1st: 3.266 (39.5 mph)
2nd: 2.130 (60.6 mph)
3rd: 1.517 (85 mph)
4th: 1.212 (106.4 mph)
5th: 0.972 (132.7 mph)
6th: 0.780 (157.5 mph @8,000 rpm)
FD: 4.764
R: 3.583
LSD: Torque response type Helical LSD
AUDM Aug 2001- Sept 2004
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
6th:
FD:
R:
LSD:
EK9
JDM 1997-2000
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
FD:
R:
LSD:
CL7 Oct 2004-2008
in-progress
Transmission Code: RBC3 / ASP3*
1st: 3.266
2nd: 2.13
3rd: 1.517
4th: 1.147
5th: 0.921
6th: 0.738
FD: 4.764
R: 3.583
LSD: Helical
FK8
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
6th:
FD:
R:
LSD:
Change log:
-v1.1.1: Updated wording
-v1.1: Added CL7 information
-v1: Initial Draft 8/1/19
DC2
JDM 1995-1996
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
JDM 1998-2000
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
1st: 3.230 (39 mph)
2nd: 2.105 (60 mph)
3rd: 1.458 (87 mph)
R: 3.000
LSD: Helical
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
FD:
R:
LSD:
Option 1: 4.785
Option 2: 4.9
in-progress
1st: 3.070
3rd: 1.636
4th: 1.310
5th: 1.054
FD:
in-progress
1st: 3.070
3rd: 1.667
4th: 1.357
5th: 1.129
FD:
in-progress
1st: 3.070
3rd: 1.700
4th: 1.410
5th: 1.207
FD:
DC5
3rd: 1.517 (85 mph)
FD: 4.764
R: 3.583
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
6th:
FD:
R:
LSD:
EK9
JDM 1997-2000
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
FD:
R:
LSD:
CL7 Oct 2004-2008
in-progress
1st: 3.266
2nd: 2.13
3rd: 1.517
4th: 1.147
5th: 0.921
6th: 0.738
FD: 4.764
R: 3.583
LSD: Helical
FK8
Transmission Code:
in-progress
1st:
2nd:
3rd:
4th:
5th:
6th:
FD:
R:
LSD:
Change log:
