Page 1 of 2
Refreshing white plastics
Posted: Wed Sep 25, 2019 2:32 pm
As Honda guys restoring vehicles, we usually don't restore hardware we replace. Well here's a helpful tip. This is used in auto, bmx , and even computer restorations use this. I planned on doing this to the discontinued white plastic that clamps on the abs lines but it won't come off without removing the abs lines it seems. I replaced the one that holds the washer fluid lines . It's pretty yellow. So I pulled two extra radiator elbows and caps for the experiment. I did this 10 years ago and it worked wonders . First thing you need is some salon grade peroxide. This stuff is a mild acid so wear gloves. In the salon industry this is known as clearer . Here's what you need.
- IMG_4212.jpg (356.93 KiB) Viewed 2590 times
You will need a clean container for whatever you plan to bleach. You also need to clean everything , that includes oil and and dirt that you can before the bath. In addition to this you need sunlight and lots of it. I started this for an example and rain showed up . It should soak in the bath for at least 5 days and sunlight. Keep in mind the stuff is aciditic, so monitor it and don't leave on vacation. I have been short on sun so this process is probably going to take longer than expected.
- IMG_4211.jpg (325.83 KiB) Viewed 2590 times
This is how yellow the 4 experiment parts went in.
- IMG_4239.jpg (218.27 KiB) Viewed 2590 times
they are supposed to stay a week but rain came after one day.
- IMG_4240.jpg (387.29 KiB) Viewed 2590 times
Re: Refreshing white plastics
Posted: Wed Sep 25, 2019 2:37 pm
- IMG_4244.jpg (223.16 KiB) Viewed 2590 times
- IMG_4245.jpg (221.25 KiB) Viewed 2590 times
See the bubbles? They are working magic. One of the floating integra elbows was brown on Sunday in the middle.
Posted: Wed Sep 25, 2019 2:54 pm
I pulled the civic reservoir after seeing success with the experimental parts. It's cleaned up better than expected, being there's no sun. Funny thing is I had a picture of it and it's missing again.
Posted: Wed Sep 25, 2019 3:11 pm
by yoshi234
Good tip
y
shi - who'll give this a try on the coolant reservoir in sunny socal
Posted: Wed Sep 25, 2019 3:25 pm
https://en.wikipedia.org/wiki/Retr0bright
Note: for non-removable\hard to remove parts cream products can be used or made with arrowroot.
Posted: Wed Sep 25, 2019 3:38 pm
yoshi234 wrote:Good tip
y
- IMG_4032.jpg (406.87 KiB) Viewed 2580 times
Hi, I found this on a bmx site. Yoshi drew it in the 80s . Q
Posted: Wed Sep 25, 2019 4:18 pm
So I can use that on the abs one ?
Posted: Wed Sep 25, 2019 4:29 pm
by yoshi234
Stin1 wrote: ↑Wed Sep 25, 2019 3:38 pm
Cool drawing
y
shi - who likes BMX and had a Diamondback SilverStreak and a Haro Master back when that drawing was made
Posted: Wed Sep 25, 2019 6:23 pm
Coat as evenly as possible, give it some heat/uv, and wash with soap and water after.
FYI this is the same hydrogen peroxide thing, wiki has the history on variations over time.
Posted: Thu Sep 26, 2019 8:09 pm
by Sp00nFedFilms
Great tip with great results. Thanks!
