Hey,
is anyone running this caliper setup on their DC2? If so which pads are you running?
Do stock DC2 pads fit? In the photo is looks as if they'd fit, but id like to verify beforehand.
Thanks,
https://art-of-attack.com/products/endl ... plications
Endless Calipers (END-DC2-202)
Re: Endless Calipers (END-DC2-202)
Just by looking at them, those are not the same shape as OEM ITR pads. AFAIK, Spoon calipers are the only ones that use OEM shape pads. Those pads may be proprietary to Endless as they appear more rectangular and have double guide pins that are closer together than Spoon's. The OEM pads are more trapezoidal, if you will. Those calipers are also radially mounted so you would need an adapter to mount them to your hubs. I don't know how to post pictures but ICB has great pics of the Spoon (OEM shape) pads for comparison.
Thanks for the info on the pads. I know about the mounting brackets.
Another user here has an Endless BBK on their caR:
viewtopic.php?f=9&t=23&start=160
What is/are your intended usecase(s)? IE daily driving only, daily driving and AutoX, daily driving and track, etc.
I would contact Endless or the reseller. My suspicion is no.
- Badge Number: 01-0388
Learn from my mistake and don't purchase an OE ITR style pad ( still stuck with the Endless OE caliper ITR brake pads I purchased). The correct part number you need is RCP066. You will have to contact endless USA as they're the only distributor for Endless parts. I went with the "Type R" compound brake pad but there are other ones depending on your car usage.
