JDM 96 Ex. Manifold, 98 spec. Header, ACT flywheel, Exedy clutch
Post by aklackner » Sun Mar 08, 2020 3:43 pm
Looking to find a new home for some collected parts that I won’t be needing.
Local pickup (San Fernando Valley) due to size and weight.
PM me.
***Updated: both include all heatshields***
98 spec JDM header asking $100 - Sold
There’s a “minor” dent on one of the lower tubes,
Dyno’d 213whp on my NA build w/ JDM cat pictured
Lower and upper heatshields included.
96 spec JDM manifold asking $70
Two piece manifold (similar to US, upper is cast lower is welded tube)
Same “JDM 2.5” collector as 98 spec. header (double walled ~60mm OD)
Inner and outer upper heatshields included
Needs new studs (joint between upper and lower)
ACT streetlight flywheel $70
Has only seen ~5000mi
Includes (installed) pilot bearing,
Exedy OEM replacement clutch (ITR) $70
Also only ~5000mi
Includes used (~5000mi) throwout bearing, ARP clutch bolts
OEM airbox $free for pickup
I’d rather not toss it in the trash if someone can use it, but won’t continue to store.
Vtecwreck
Re: JDM 96 Ex. Manifold, 98 spec. Header, ACT flywheel, Exedy clutch
Post by Vtecwreck » Sun Mar 08, 2020 4:32 pm
Pmd
Post by aklackner » Sun Mar 08, 2020 4:43 pm
Vtecwreck wrote:Pmd
Thanks but due to size and weight I’m not looking to ship at this point.
Post by DC231 » Mon Mar 09, 2020 9:07 am
Would you consider shipping the clutch kit? 32220
Users browsing this forum: Bing [Bot] and 3 guests
