Restoring #97-00012
Re: Restoring #97-00012
You have any ideas where this bracket/plug are located on the pass. side? I'm betting the ABS 4-pin plug goes into the relay (although OEM parts catalog shows 2 relays, backup?)
- Dc2-ProductionS
- Badge Number: 97-00012
I mounted that right next to the radiator. It is in the loom very close to the fan connections. There is also a mount hole with body hook that fits that piece perfect on the rad support. Ill post some pictures for ya
Awesome, thanks. Any idea on what the function of it is for? It's a relay for ABS, but what exactly for?
such a cool build, cant wait to see this finished GO... #12!!!!
- Dc2-ProductionS
I think it may be a relay for the actual large modulator unit on passenger side if I was to guess before digging into it. Here is where I found mount holes for mine.... It showed it in this kind of position in the manual I have and seemed to fit well here.
The bracket is mounted on pass frame but relay sits under mount for pass headlight. If you see close, the finger tab fits in hole also....
Also had a hell of a time finding this bracket and getting it cleaned up and set in place. We're working on getting the center console brackets and hardware in place so it can eventually be set in, but we just realized the dash may have to be disconnected and slide back out. But more on that later.... Here is bracket I cleaned up and got in place. Also got the hardware I needed for the e-brake cable to get them tied down and handle mounted in place.
Small stuff but all steps in the process!!
Thanks man! Build thread is motivating me to post some updates on mine since I've got Corona down time.
Please do! I would enjoy updates on your car. I also need to pic a photo host myself and recreate my build thread.
- Dc2-ProductionS
So I got some more details on the EVAP unit. I got the canister and lines all cleaned up. Also took some detail pics so others can see how its routed.
BEFORE:
AFTER:
Also got the windshield cowl cleaned up....
Another big step was getting the headliner cleaned up, finding all the little shimmer gray tabs, the passenger "oh shit" handle, cover caps, and that pesky tiny little piece that goes between the headliner and the rear view mirror. Headliner is in, and looks.....
fa-ha-ha-hannn-tasticcccccccccc
Also forgot to tell everyone I spent way more money than I should have, but had to get it......
Took the IM back off and wanna get the firewall all buttoned up as well as the back of the engine. I need to scour some pictures and get some good placement and eyes on all the little brackets and holders for the lines. I know we are gonna miss some and have to crawl under and break our wrists in half to get back at some of them, but thats what its all about!..... right?
to covid-19 for letting me get 2hrs a day in the garage to work on the caR.....
Stay tuned....
BEFORE:
AFTER:
Stay tuned....
Looks Great! excited to see this thing get back on the road! keep up the great work!
What are you using to clean and protect the plastics?
