oem shock replacement
eericc
Post by eericc » Fri Oct 16, 2020 3:31 pm
Hello all,
Where do you folks go for oem type r replacement shock and struts? and what brand
Dpine
Re: oem shock replacement
Post by Dpine » Tue Oct 20, 2020 7:06 pm
If your in North America I think your only options are:
Bilstein B8's or Koni Yellows for the rear that would be closest to an oem style rear strut.
Post by Outrun » Thu Oct 22, 2020 4:24 pm
Curious if anyone has used Eibach dampers with OEM springs.
EDIT: I just checked Eibach's site and didn't see any dampers listed. Just Pro-Alignment parts.
Post by coolhandluke » Fri Oct 23, 2020 12:32 pm
Outrun wrote: Thu Oct 22, 2020 4:24 pm Curious if anyone has used Eibach dampers with OEM springs.
My understanding is Eibach discontinued the Multi-Pro R2's due to limited Honda sales. :(
Post by Outrun » Fri Oct 23, 2020 1:21 pm
They had some Pro-Dampers years ago that could be used with OEM ITR or Eibach ITR Pro-Kit springs. Low Honda sales must be why they also discontinued 92-95 Civic Pro-Dampers, which actually work well with stock springs on my 94 sedan. OEM Honda/Showa shocks for the Civic are also discontinued.
eericc
Post by eericc » Fri Oct 23, 2020 2:06 pm
I'm running B8's with OEM ITR springs. They are just too stiff for my liking and where I live that have horrible roads. I'll probably get some Koni yellows and put them at the softest settings and warranty my B8's to get fresh ones and resell them. Sad that some parts that usually need changings are being discontinued.
