The Replacement Parts Thread
Klasse
Re: The Replacement Parts Thread
Post by Klasse » Sun Jun 20, 2021 11:48 pm
Thanks, it does let me check out with them. Shipping kind of kills it (should have said I'm in New Zealand), but ill keep it in mind. I really just want the upper ball joint but Honda won't let you it seems.
Anyone know the difference between 010 and 020 front upper control arms? Probably some tiny change in chamber I'm guessing.
carpayments4life
Post by carpayments4life » Fri Sep 17, 2021 7:57 pm
The original Left Rear ABS sensor, for my Type R (part 57475-ST7-801) is no longer available, but I bought and successfully used the sensor for a 2000 Integra LS w/auto (part number 57475-ST7-A01). The orange connectors are the same size and all but one bolt hole lines up.
Post by Stin1 » Sat Sep 18, 2021 10:52 am
Adler is oem supplier for the clutch master and slave cylinders. They are identical in every detail and made in Japan. The master cylinder even has the nissin logo. Save your self some bucks vs. the dealer.
Post by Stin1 » Sat Sep 18, 2021 11:00 am
Klasse
Post by Klasse » Mon Oct 11, 2021 6:01 pm
It appears the Ignitor 30130-P72-006 is discontinued now too. Just a warning for anyone looking!
oddomatik
Badge Number: 98-0542
Post by oddomatik » Tue Oct 12, 2021 6:13 am
2-3 years ago I recall seeing zero-mile heads built with valvetrain for $2500 on many different parts sites, and now I can find none. I'd like my zero-mile block to be less lonely. Anyone have a source or have these entered the realm of unobtanium?
SpecE30 | RAM 3500 | CB550
Post by aklackner » Tue Oct 12, 2021 10:41 am
When I put together mine the recommendation I got was to stay clear of the remaining new castings. Reportedly they weren’t as clean as earlier ones. I went with a used head, had it cleaned inspected, refreshed and a full valve job done on it by Portflow. They have a specific cnc program for b18c5 valves that delivered amazing results.
oddomatik
Post by oddomatik » Tue Oct 12, 2021 10:50 am
aklackner wrote: Tue Oct 12, 2021 10:41 am When I put together mine the recommendation I got was to stay clear of the remaining new castings. Reportedly they weren’t as clean as earlier ones. I went with a used head, had it cleaned inspected, refreshed and a full valve job done on it by Portflow. They have a specific vnc program for b18c5 valves that delivered amazing results.
Nice tip and good to know - thanks!
Post by jayhaire » Tue Oct 12, 2021 11:08 am
A used b16 head sent to a proper shop would be a good alternative. Thanks for sharing the tip about newer castings. I had not heard that.
Post by coolhandluke » Thu Oct 14, 2021 12:27 pm
I fear I waited too long to find a good used head for when I want to move back towards a stock build.
