Post
by coolhandluke » Fri Apr 20, 2018 3:33 pm
Are you asking if you can replace just the ignition harness?
Post
by Outrun » Fri Apr 20, 2018 5:40 pm
I think I need part number 35100-SR3-A03, which includes a new key and key cylinder.
I know how to take the key cylinder out (turn key and push pin to get cylinder out) and was wondering if that existing key cylinder will work in the new ignition switch (wiring and ignition lock assembly).
ddwelch
Post
by ddwelch » Tue Apr 24, 2018 2:55 pm
Dang that sedan looks clean!!!
Post
by Outrun » Tue Apr 24, 2018 5:36 pm
I tried the key cylinder from my 1994 coupe and it fit so the plan is to just get a replacement aftermarket ignition switch assembly and reuse the current sedan's cylinder.
Yes it's pretty clean for the age. Leaks water inside the cabin when it rains too =( Will pull the cowling and carpeting eventually to find where the water is getting in.
Post
by Outrun » Mon Apr 30, 2018 12:42 am
I ordered a generic ignition switch assembly from Rock Auto. I took the wiring from the generic one and replaced the one in the car while keeping the original key cylinder and now everything works fine.
Routing the wiring was a bit difficult because of the tight space. I wasn't able to reuse the two cable ties from the original wiring that attached to two places under the dash but the new wiring seems secure under there.
4DoorITR
- Badge Number: DB81200887
Post
by 4DoorITR » Thu Feb 02, 2023 3:46 pm
Outrun,
SORRY for necroing this post. Do you still own this? If so, did you discover clogged sunroof drains causing the leak?
Also...willing to sell it?
'96 DB8 Type R
'92 EH9 EX
Post
by Outrun » Thu Feb 02, 2023 7:01 pm
I still own it. Installed a BNIB chin spoiler from ICB in Arizona last year. Currently has 227k miles. Bought two sets of OEM style foglights but the quality sucks (one kit was from Auto88 on Amazon, the other is from Spec D Tuning). Replaced worn OEM dampers with Eibach Pro-Kits and the handling is much improved even with the stock springs. I'm mad I procrastinated on getting more Eibachs when they were on clearance for $180 for a set of four! I also installed a DC Sports strut bar from Heeltoe. I have a DC Sports cold air intake, 4-2-1 header, and exhaust but I haven't installed them yet as I want to dyno test before and after they're installed.
I'm keeping the car and also looking for a white 1994 Civic Si with ABS and a white 1994 del Sol Si to complete my 1994 Civic collection (I also have a 1994 Civic EX coupe with 503k miles).
I haven't checked the sunroof drain yet.
