1997 Gsr & 2002 AP1 track/build log
Re: 1997 Gsr(and other cars) track/build log
Post by coolhandluke » Mon Oct 30, 2017 7:26 pm
PatHidden wrote: Mon Oct 30, 2017 2:01 am
I'm glad too. I am trying to go to Hff Finale in Dec. You should come out!
What are the dates? I assume BW? I typically miss it due to being away for Christmas, I can try as a track season finale.
PatHidden wrote: Mon Oct 30, 2017 2:29 am ...Based on what I was seeing from tire temps, I either needed softer springs in rear or less camber. I went with the softer spring because I could always get the rear stiffer from my rear sway. The rear sway has always been on full soft. Also, from what I read, I should tune with springs first before anything else. Not sure how accurate that it, but I am doing it. :P
I also added the thrust bearings to help the spring turn during high stress. Not sure if it will be noticeable but they were cheap...
Great write up! You have the wheels spinning, time for me to read more into dialing in my setup. Best wishes with testing out the setup changes. :beer:
Post by Outrun » Tue Oct 31, 2017 7:30 pm
Last two HFF events are Sunday, November 19, 2017 at Chuckwalla and Saturday, December 16, 2017, at Buttonwillow.
PatHidden
Post by PatHidden » Thu Nov 02, 2017 1:49 am
coolhandluke wrote: Mon Oct 30, 2017 7:26 pm
Outrun wrote: Tue Oct 31, 2017 7:30 pm Last two HFF events are Sunday, November 19, 2017 at Chuckwalla and Saturday, December 16, 2017, at Buttonwillow.
Yes, the Finale is December 16 at BW.
Also after texting Ryan, I thought I would post some links I reference when taking tire temps and responses to the data.
http://949racing.com/using-a-tire-pyrom ... acing.aspx
https://nasaspeed.news/tech/wheels-tire ... racetrack/
Small update for this weekend.
Post by Lturner » Thu Nov 02, 2017 7:05 pm
Good stuff.
g3teg97
Badge Number: 98-0379
Post by g3teg97 » Mon Nov 06, 2017 2:37 pm
What wheels are you running? The stance, wheel size, tire size and drop look perfect imo
Post by coolhandluke » Mon Nov 06, 2017 5:14 pm
g3teg97 wrote: Mon Nov 06, 2017 2:37 pm What wheels are you running? The stance, wheel size, tire size and drop look perfect imo
They are TE-37SL's in 15x8''. Patrick can confirm the offset, my guess is +32 or +35.
PatHidden
Post by PatHidden » Mon Nov 06, 2017 5:32 pm
coolhandluke wrote: Mon Nov 06, 2017 5:14 pm
Correct and my offset is +32. Also, I am running a 225/45/15 Nitto NT01. The last time I set the ride height slightly lower than prior.
g3teg97
Post by g3teg97 » Tue Nov 07, 2017 7:33 am
PatHidden wrote: Mon Nov 06, 2017 5:32 pm Correct and my offset is +32. Also, I am running a 225/45/15 Nitto NT01. The last time I set the ride height slightly lower than prior.
Thanks...they look awesome.
PatHidden
Post by PatHidden » Sat Dec 23, 2017 10:29 pm
November Speedventures @ Chuckwalla:
First track day on new suspension updates.
So I was lazy and didn't get as much data as I wanted. If I remember correctly, front tire temps were not at even as prior, but could be just a psi thing.
Well, the car was a lot more neutral this time around with the spring change. I may need to bump the rear sway up for more rotation and try to counteract throttle exit understeer. The 1.5 LSD is showing its face now.
Only other thing, about the chuckwalla weekend, was the brakes. The rears seems to want to lock up easier than I remember.
Anyways, I got 1st in Mod class. :trophy:
Chuckwalla CCW pb lap 2:05.95, probably should be ~3 secs faster. so time is everywhere, this was my first time doing CCW:
https://www.youtube.com/watch?v=BNINFPaS2yA&t=4s
Chuckwalla CW pb lap 2:05.88, same as CCW ~3 secs can be shaved. 4 years ago I I did a 2:08.xxx on CW:
https://www.youtube.com/watch?v=eJ5hd57d6ko&t=11s
overall a good weekend.
Me being me:
PatHidden
Post by PatHidden » Sat Dec 23, 2017 10:44 pm
Updates:
Fresh NT01s
So I decided to purchase new NT01s. I've always bought used nt01s from buddies or craiglist specials. the Nt01s I used for chuck,and my last time at buttonwillow, were dated 2014. Now idk how they were stored or if they lost grip but I thought new ones would be better.
December Speedventures @ Buttonwillow Hff Finale:
Honestly this track weekend was a wash in terms of tuning. I was having too much!! to focus to much on the car.
I didn't pb, track conditions were kinda dusty the whole weekend. I clicked off a 1:59.9. Everyone seemed to be off pace for the weekend. After first session on the second day, I came in the pits and noticed I had no rear pad at all. I need to upgrade, I've been using oem. I'm gonna get xp8s for the rears. I sourced some pads that worked and went out second session. I didn't get a clean lap and on my flier my distributor rotor decided to come loose.
resulting in:
Surprisingly, the auto parts store didn't have one. I decided to pack up and head home.
all of first session from second day:
https://www.youtube.com/watch?v=r3SVWkkAScs&t=333s
my 1:59.9 lap:
https://www.youtube.com/watch?v=p2DUvNOZ2PU&t=59s
Passenger PB 2:02.6:
https://www.youtube.com/watch?v=3Y0K_-MNSUg
Bloopers!!
https://www.youtube.com/watch?v=K6j8uXnp2tM&t=10s
Some pics:
Thanks for reading guys!
