VSM ITR build 01-0388
Re: VSM ITR build 01-0388
Post by coolhandluke » Tue Mar 17, 2020 4:52 pm
That Carbing strut bar looks great against the VSM. 8-)
I hope the 3wks off isn't impacting you financially. Either way, best wishes and enjoy the wrench time.
PeteTheCarFreak
Post by PeteTheCarFreak » Tue Mar 17, 2020 6:35 pm
coolhandluke wrote:That Carbing strut bar looks great against the VSM. 8-)
X2
Insidiouseg6
Badge Number: 01-0388
Post by Insidiouseg6 » Thu Mar 19, 2020 9:56 pm
DC4MC wrote: Tue Mar 17, 2020 8:32 am Brake lines look great! I need to get motivated to go and do mine. I have to bend new hard lines to the rear though as well. When I dropped my lines to do my undercoat I realized mine weren't in great shape.
Looking forward to seeing this thing together!
Dang rear lines also? Long lines can be a pain! Best of luck bud
coolhandluke wrote: Tue Mar 17, 2020 4:52 pm That Carbing strut bar looks great against the VSM. 8-)
Thankfully it's paid. It involves doing a little bit if work from home but it's like 2 hours per day.
Insidiouseg6
Post by Insidiouseg6 » Thu Mar 19, 2020 10:03 pm
Got the lines going to the Master Cylinder done yesterday!
Insidiouseg6
Post by Insidiouseg6 » Thu Mar 19, 2020 10:16 pm
Also picked up the interior brackets from the powder coater! Dude did a great job.
Test fitted the brackets
And lastly, almost completed the brake lines, waiting on a fitting from Jegs then it should wrap that up
Post by DC231 » Fri Mar 20, 2020 11:11 am
Insidiouseg6 wrote: Thu Mar 19, 2020 10:16 pm Also picked up the interior brackets from the powder coater! Dude did a great job.
Be aware you will not get a good ground connection though the powder coat. I would grind down the coat anywhere you will use as ground.
Insidiouseg6
Post by Insidiouseg6 » Tue Mar 24, 2020 2:09 am
DC231 wrote: Fri Mar 20, 2020 11:11 am
Appreciate the reminder! That will definitely happen when I get to connecting everything Inside the cabin.
Back at it with more progress!
Picked up a set of PCI spherical rear camber arms to replace the old Blox ones.
Got started on the headlight wire harnesses. Completely de loomed the harness and re wrapped it after getting rid of some unneeded connectors (washer fluid, ac fan etc)
The passenger side was a bit more work because I had to strip the harness and get rid of all the ABS connectors then re wrap it. The original harness had been hacked by the previous owner so I was able to find the original connectors for the headlights on eBay so will solder those and finish up once they arrive
Now we move towards the inside wiring. It was a real tight squeeze with the brake lines but the main harness was able to fit in.
Post by coolhandluke » Tue Mar 24, 2020 10:31 am
This is coming along nicely! I understand the hours required for the wiring work. I'm having flashbacks to 2007 for my rebuild. I tip my hat to you finding the original headlight connectors, that's a move that will pay dividends later. I need to find USDM connectors myself...
Keep up the quality work!
Rigo.Left
Post by Rigo.Left » Wed Mar 25, 2020 12:30 pm
Loving the build! Keep it up brotha. More pics on instagram too haha as I'm following it on there as well. :thumbup: :thumbup:
PeteTheCarFreak
Post by PeteTheCarFreak » Wed Mar 25, 2020 6:10 pm
Looks fantastic
