- IMG_4327.jpg (268.72 KiB) Viewed 2720 times
Re: 98-0940 Anyone know anything about the caR?
Screw you !!!!!
This is what Acura provided for my cup / cubby hardware. This is what I think spoon received as well. This is the screw behind the door panel. Not only is it the wrong color for the cubby, and no washer, the threads are different.Re: 98-0940 Anyone know anything about the caR?
New weatherstripping
I think I figured it out.
There's two pockets pictured in the parts diagram. The lower pocket should be pictured as a bracket for the pocket. The top one is the cup and screw.Re: 98-0940 Anyone know anything about the caR?
Can someone confirm what the original screw should look like?
Happy Halloween ! The great pumpkin handed me this for 2019.
Those are impressive cuts.
Where did you purchase this tape? I am about to run through this process.
I got it at oreillys but google seemed to show Walmart and every auto store had it too .coolhandluke wrote: ↑Thu Oct 31, 2019 5:23 pm Those are impressive cuts.
The door pull pocket uses a black tapping screw (90101-S03-000)
The door pocket at the bottom of the door consists of two pieces and is attached with two screws (93913-14220) installed behind the door lining.
Thanks for that! Mark said that you checked and confirmed no washer on the black screw for the pocket correct? I didn't even think of that lower pocket.
Hmm I didn’t speak with spoonfed about it. But that’s correct, no washer on the black screw. I haven’t had a Teg door panel off in years so can’t remember what the bottom pocket screws look like... probably like the silver screw pictured above, just different part number.
