WTB: 1/4 Panel Inner, rear trunk, hatch plastics, and door panels
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Tue Jun 05, 2018 11:43 am
Hey everyone, I've been hunting for these for quite sometime, I have faith someone somewhere will see it and be willing to part ways. The only drawback, I'd like them close to new (IF YOU HAVE NEW LMK I'LL PAY) as possible. They must be from a 98-01 Integra, given they have the rear crash support cutout. Door panels; same, as new as possible as well, w/ tweeters. If you know of anyone feel free to tag me, or let them know I'm looking. Please.
Thanks,
Joel ( M.9097285033)
FOUND
yoshi234
Badge Number: 234
Re: WTB: 1/4 Panel Inner, rear trunk, hatch plastics, and door panels
Post by yoshi234 » Thu Jun 07, 2018 12:21 am
This shop in Fresno just posted door panels
https://instagram.com/p/BjtgEQ9FCgG/
00 ITR #234
00 Bolt EV
21 Highlander Hybrid
:geek:
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Thu Jun 14, 2018 2:23 am
Thanks Yoshi, but those are too beat for me.
Post by coolhandluke » Thu Jun 14, 2018 6:57 pm
Asspenny was giving away most of these parts at Expo East. He had several posts:
-viewtopic.php?f=13&t=342
-viewtopic.php?f=13&t=334
*His 1/4's are still available
Integrao is also selling my 1/4 interiors, although notched for Mugen rear strut bar:
viewtopic.php?f=13&t=366
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Thu Jun 14, 2018 8:32 pm
coolhandluke wrote: Thu Jun 14, 2018 6:57 pm Asspenny was giving away most of these parts at Expo East. He had several posts:
I ended up buying some hatch panels from IntegraO, just last night. I need to send him over a shipping label. His rear 1/4's unfortunately are a bit too much for me. Thanks for looking out you guys.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Thu Jun 28, 2018 11:24 am
Still looking, very motivated buyer. Most important ATM is sourcing the mint rear panels.
Derek
Post by Derek » Thu Jun 28, 2018 2:17 pm
I have a brand new rear 1/4 from a 97 ls I just pulled out of the attack. Don't remember what side but can look this evening. Double checked the p/n and they are the same between it and my 00 R.
00-1020
formerly 00TypeR
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Thu Jun 28, 2018 11:25 pm
It should have provisions for the rear crash bar if it’s the “same,” if we can verify that, I’d gladly take that of your hands.
Post by aklackner » Fri Jun 29, 2018 1:47 pm
@JDMJNKY Are you talking about the rear performance bar (inside the hatch bolts to welded nut on frame rail ends), the rear bumper support (outside but slides into frame rails), or something else?
Neither performance bar nor bumper support should affect the side covers.
The rear bumper support bolts in the same place on all the g3 integra models Type R or not.
The Performance bar only covers the center rear plastic (this one is ITR specific) but does not extend as far as the rear side plastics.
I actually put the ITR performance bar on my old LS by adding rivnuts to the frame rail ends where the ITR has a welded nut. I had to modify the rear center plastic (tan interior so ITR panel wasn't an option) but can verify there was no impact to the side plastics.
Hope this helps.
JDMJNKY
Badge Number: 0874
Post by JDMJNKY » Fri Jun 29, 2018 5:07 pm
aklackner wrote: Fri Jun 29, 2018 1:47 pm @JDMJNKY Are you talking about the rear performance bar (inside the hatch bolts to welded nut on frame rail ends), the rear bumper support (outside but slides into frame rails), or something else?
Hope this helps.
Thanks for chiming in. I’m actually referring to interior plastics. They start at the rear seating area and flow into the trunk. For 98-01 there’s a small cut out that makes them unique. I’m unsure if it’s available in the 97 trim, I’d hope it’s the same. New or used I’ve been desperately looking for them; AS MINT AS POSSIBLE. The JDM ones are not the same as 98-01, because they follow USDM 94-97 provisions so to speak.
You can use 98-01 panels in a 94-97 but not vice versa, unless you remove the black crash/seat bar.
