Backup camera install into /////Alpine ILX-007
I recently installed a backup camera eRapta ERT02 2nd Gen.
(link to Amazon where I bought this setup)
https://amzn.to/2YnuDoU
Installation was fairly straight forward. I had the interior removed already so tucking and fishing of wires and cables was much easier to do a clean install.
A. Two power wires (one attached to yellow RCA and other goes straight to camera) spliced into reverse light
B. RCA from camera attached to extension RCA that goes to headunit
C. Camera wiring routed through the stock grommet
D. Connector from the camera plugged into power and ground
E. Attached the camera ground wire to the stock grounding location
You can see the grommet behind the license plate
Green circle - Red wiring coming off the RCA cable is connected to the "REVERSE" wire coming off the headunit. This lets the headunit know when the car is put into reverse and for image to appear on screen.
Everything installed and inspected
y
shi - who found this install way easier than he thought
