1997 CDN ITR ecu, Comptech Race ECU
Sporky82
Badge Number: searching
Post by Sporky82 » Fri Oct 04, 2019 3:32 pm
Hey everyone,
I have a genuine 1997 Cdn ITR ecu p73-c02
In my car tested and working (I have a '95 GSR swapped with a 1997 Cdn ITR swap)
$900 shipped plus fees
Also I have a ultra rare Comptech ITR Race ecu OBD2A, vtec engagement at 5100ish rpm, redline 9000rpm with remapped ignition and fuel maps. Designed to be used with comptech spec parts ie: icebox, header and exhaust.
I have two out of the three, no comptech header but using a JDM 4-1, afr's are still safe. This ecu is crazy fun to drive on the street and I can only imagine what it's like on a track. Drives like stock till you get into it.
$550 shipped plus fees - Hopefully someone with a true ITR with these bits can have themselves a period correct build
Type R
Re: 1997 CDN ITR ecu, Comptech Race ECU
Post by Type R » Fri Oct 04, 2019 6:11 pm
That’s a 98 GS-R Ecu
@USDMITR
Sporky82
Post by Sporky82 » Fri Oct 04, 2019 8:04 pm
Its comptech software for an ITR installed in a p72. Confirmed by comptech, this was used in one of their factory racecars.
You can give them a call
Sporky82
Post by Sporky82 » Thu Oct 10, 2019 4:00 pm
Video of the ecu in my car, start up and idle
https://youtu.be/G7SYTufphz4
Type R
Post by Type R » Thu Oct 10, 2019 8:57 pm
Sporky82 wrote: Fri Oct 04, 2019 8:04 pm Its comptech software for an ITR installed in a p72. Confirmed by comptech, this was used in one of their factory racecars.
They have been closed down for the better part of a decade.
@USDMITR
Post by Stin1 » Thu Oct 10, 2019 10:52 pm
So does that Canadian ecu communicate with the scan tool? How does it work in a usdm car? The Canadian one doesn't use the eld I understand.
Sporky82
Post by Sporky82 » Fri Oct 11, 2019 1:03 am
Type R wrote: Thu Oct 10, 2019 8:57 pm
Comptechusa.com is still in business, they only focus on race applications not the aftermarket parts
Sporky82
Post by Sporky82 » Fri Oct 11, 2019 1:07 am
Stin1 wrote: Thu Oct 10, 2019 10:52 pm So does that Canadian ecu communicate with the scan tool? How does it work in a usdm car? The Canadian one doesn't use the eld I understand.
Yes it works with the scan tool, plug n play in a usdm chassis. And correct Canadian cars didn't use the eld, you can disconnect it via the under hood fuse box.
Sporky82
Post by Sporky82 » Mon Oct 21, 2019 2:55 pm
Price drop on the comptech ecu
Sporky82
Post by Sporky82 » Fri Nov 08, 2019 12:06 pm
Both sold
