1997 CDN ITR ecu, Comptech Race ECU
- Badge Number: searching
Hey everyone,
I have a genuine 1997 Cdn ITR ecu p73-c02
In my car tested and working (I have a '95 GSR swapped with a 1997 Cdn ITR swap)
$900 shipped plus fees
Also I have a ultra rare Comptech ITR Race ecu OBD2A, vtec engagement at 5100ish rpm, redline 9000rpm with remapped ignition and fuel maps. Designed to be used with comptech spec parts ie: icebox, header and exhaust.
I have two out of the three, no comptech header but using a JDM 4-1, afr's are still safe. This ecu is crazy fun to drive on the street and I can only imagine what it's like on a track. Drives like stock till you get into it.
$550 shipped plus fees - Hopefully someone with a true ITR with these bits can have themselves a period correct build
Re: 1997 CDN ITR ecu, Comptech Race ECU
Its comptech software for an ITR installed in a p72. Confirmed by comptech, this was used in one of their factory racecars.
You can give them a call
They have been closed down for the better part of a decade.
@USDMITR
So does that Canadian ecu communicate with the scan tool? How does it work in a usdm car? The Canadian one doesn't use the eld I understand.
Comptechusa.com is still in business, they only focus on race applications not the aftermarket parts
Yes it works with the scan tool, plug n play in a usdm chassis. And correct Canadian cars didn't use the eld, you can disconnect it via the under hood fuse box.
Price drop on the comptech ecu
Both sold
Users browsing this forum: Google [Bot] and 3 guests
