Spoon Twin Block Helicoil Separation
Little_Nolan
Re: Spoon Twin Block Helicoil Separation
Post by Little_Nolan » Wed Jul 29, 2020 3:02 pm
Installed the calipers. Everything bolted up fine and spacing appears correct.
I used the washer in between the bolt and hub.
Now I have to bleed the brakes
Post by coolhandluke » Wed Jul 29, 2020 4:23 pm
As long as the caliper is centered over the brake rotor, you're good. :thumbup:
Little_Nolan
Post by Little_Nolan » Wed Jul 29, 2020 6:08 pm
Just took it out for low speed testing and then some light pad bedding.
Everything seems to be working just fine. I am going to remove the front wheels and double check all the bolts and what not but the pedal feel is great and there is less vibration/noise in the front end compared to previously.
Post by coolhandluke » Thu Jul 30, 2020 9:50 am
Little_Nolan wrote: Wed Jul 29, 2020 6:08 pm Just took it out for low speed testing and then some light pad bedding.
Excellent work! I'm very impressed. This seemed like a daunting project but I'm thrilled with your results. :thumbup:
Post by RTW DC2R » Thu Jul 30, 2020 10:03 am
:thumbup: Good jorb!
Little_Nolan
Post by Little_Nolan » Thu Jul 30, 2020 6:28 pm
Thanks for the nice words gents.
Took it out again for a puttering around my block and no issues or leaks. Overall pretty happy... slightly disappointed with the Hawk HPS 5.0s on initial impression but I think I can bed them in better - we will see.
navin
Post by navin » Fri Jul 31, 2020 1:35 pm
If you have one of those Motive power bleeders, try that. I love using it now after doing some modifications to make sure the cap (universal) cap seals -- ie. 2 c-clamps clamping it down.
Little_Nolan
Post by Little_Nolan » Fri Jul 31, 2020 3:57 pm
I do not have one of the motive bleeders.
What is the clamp modification you're referencing? I am considering picking up one of the bleeders after doing some quick research.
