neatrip
Post
by neatrip » Mon Mar 22, 2021 1:12 am
Sorry for a dumb question, but I recently acquired a replacement valve cover with a broken oem barb connector that usually routes to an optional breather filter or 3/8 I.D. hose to the intake arm.
I will have to drill out the old barb and re-install a replacement. Does anyone know a good replacement barb size that will fit like the original one without having to tap a larger opening in the valve cover to install it?
Searched around the forums for any info, but only found the usual vented valve cover how-to's.
Thank you for any information!
Post
by coolhandluke » Mon Mar 22, 2021 10:20 am
Can you post a picture? I believe I am followed but I want to be 100%.
neatrip
Post
by neatrip » Mon Mar 22, 2021 10:13 pm
Thanks, the circled part on valve cover.
neatrip
Post
by neatrip » Tue Mar 23, 2021 1:13 am
Wow, thanks for your time and suggests.
Good idea with the fuel line adapter. I notice the AGS adapter description and your advice says nylon tip, the pic shows all metal or am I mistaken?
I was wondering if there was absolutely not a 3/8" to 3/8" possibly available as far as other 3/8 fittings are concerned but was only able to find NPT to barb adapters as your suggested.
TIA for any others.
Post
by coolhandluke » Tue Mar 23, 2021 11:07 am
Thank you for confirming.
I have not read of anyone replacing this piece. I now King Motorsports works on valve covers, both refinishing and modifying for venting. Alternatively, purchasing net-new is an option.
shuttlepilot
Post
by shuttlepilot » Tue Mar 23, 2021 6:51 pm
neatrip wrote: ↑Tue Mar 23, 2021 1:13 am
TIA for any others.
When I said nylon tip side, I mean the longer smaller diameter nipple side which usually gets forced into nylon fuel line. If you are doing the NPT thread, remember the threading is a tapered so carefully tap only to the depth you need.
There might be an adapter to join hose to hose, but usually they are the serrated multiple barb type. Go to
www.mcmaster.com and search through their selection using the key words "hose union barb". You can also consider getting 10mm annealed thin wall tube and then having a hydraulic shop bead and shape it for you using brake flaring tools.
neatrip
Post
by neatrip » Thu Mar 25, 2021 12:32 am
Very informative, I will most likely use the fuel line adapter method as 10mm 3/8" is so hard to find.
Thanks again.
Users browsing this forum: Bing [Bot] and 2 guests
