FS: Usdm rear seat
Sporky82
Badge Number: searching
FS: Usdm rear seat
Post by Sporky82 » Tue Jan 03, 2023 5:04 pm
Selling my spare usdm rear seat
No burns, cuts or holes etc.
Slight fade on the top edge
Excuse the "dents" they are stacked in the trunk of my itr.
Quick clean with some woolite and they will look great
$400 plus shipping, PayPal goods and services only.
Re: FS: Usdm rear seat
Post by AndyD » Tue Jan 03, 2023 6:00 pm
Where are they located? Potential buyers would definitely like to know.
What's the story on your ITR? Looks partially disassembled. Engine on the stand and transmission on the ground I believe.
Type R
Post by Type R » Tue Jan 03, 2023 6:50 pm
FYI have to be careful how you store seats 25 year old foam doesn't have the memory it once did and there is a good chance it won't bounce back
@USDMITR
Sporky82
Post by Sporky82 » Tue Jan 03, 2023 9:15 pm
AndyD wrote: Tue Jan 03, 2023 6:00 pm Where are they located? Potential buyers would definitely like to know.
Opps thanks for the good eye
Seats are in Vancouver Canada and I have very good shipping connections
Spun bearing in April of 2021 and have been waiting/searching for a compent machine shop for the rebuild
Sporky82
Post by Sporky82 » Tue Jan 03, 2023 9:16 pm
Type R wrote: Tue Jan 03, 2023 6:50 pm FYI have to be careful how you store seats 25 year old foam doesn't have the memory it once did and there is a good chance it won't bounce back
Appreciate the heads up, the seats have already come back and with the help of a hair dryer they will look like nothing happened. Had a set of leather seats in far worse shape and they came back with some heat and massaging
Post by DC231 » Wed Jan 04, 2023 6:58 am
Sporky82 wrote: Tue Jan 03, 2023 9:15 pm
Have you sourced a crankshaft? You will definitely need one if you spun a bearing and most likely you will need one rod at minimum.
Sporky82
Post by Sporky82 » Wed Jan 04, 2023 12:02 pm
DC231 wrote: Wed Jan 04, 2023 6:58 am Have you sourced a crankshaft? You will definitely need one if you spun a bearing and most likely you will need one rod at minimum.
Yes I was fortunate and found 3 usdm itr cranks and 2 gsr cranks, spare CDM/usdm c5 block, Connecting rods were available new from Acura so I ordered all four.
Post by Dc2-ProductionS » Wed Jan 04, 2023 12:58 pm
Sporky82 wrote: Wed Jan 04, 2023 12:02 pm ......Yes I was fortunate and found 3 usdm itr cranks and 2 gsr cranks.......
Do you have a R crank available for purchase? PM sent
Users browsing this forum: Bing [Bot] and 2 guests
